thoughts on Digitech Space Station eprom copying?
Started by Processaurus, June 07, 2007, 10:02:50 PM
mongo
Opened my commodore, no dice, no good ol' 41464 inside  :icon_frown:
digi2t
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
Govmnt_Lacky
Just a quick thought...
Try to meter out the sockets for the added RAM. It would be a shame to buy new chips and find out you had a cold/bad solder joint.
Food for thought.
mongo
I've been very busy since last week, I hope to update the status of my mod this weekend
Swamp
Searching somo info for the ram on comodore and amiga 1000 websites.
here some compatible rams.
http://www.c64-wiki.de/index.php/RAM/Herstellercodes
Govmnt_Lacky
Quote from: mongo on February 25, 2015, 08:37:55 AM
Any update on this?
Quote from: Swamp on March 17, 2015, 07:53:03 AM
Cheers! And thanks for the link  ;)
Swamp
#427
tested today some of the chips I bought last year for this Xp-all Project.
NEC USA D41464C-10 8937VA91   OKAY
I tested one of the XP200 I have and it sound like shit, the modulated sound is very distorted.
The signal enter okay in the ADC, and get´s out bad from the DAC.
The DAC is a CS4330 from Cirus logic, obsolete now.
http://floe.butterbrot.org/matrix/hacking/limp/docs/cs4330.pdf
After some search the equivalent is an CS4338 by cirus logic too.
http://www.cirrus.com/jp/pubs/proDatasheet/CS4334-5-8-9_F6.pdf
Really hope its the DAC that is faulty.
Those chip are prety cheep, maybe it can be a improvement on the xp sound. I will see.
UPDATE
used the DAC and ADC from another unit. and they are okay.
Anyone had this problem with any XP family pedal?
Swamp
and more...
To have an output Volume control.
Why not making the same as done on the Line6 DL-4?
a pot in the place of r27 and r18 to control the gain of the output opamp U5
or maybe changing r25 and r23.
Not interested in making such mod, but i can try.
slacker775
I'm getting my XP-100 -> XP-ALL+ build started and have a likely simple question - from what I can tell from the doc, the only wiring from the main PCB to the EEPROM adapter board is the two for R30, correct?  The 5V that I pull near the regulator goes to the switch and provides + for the LEDs, and VSS from the adapter PCB is ground, used at the switch as well as the LEDs.  The wires from the MC34064P connect to the 6P4T.  A14/15/16 from the adapter go to the switch for switching firmware from the EEPROM.
digi2t
Quote from: slacker775 on May 26, 2015, 04:00:43 PM
Vss connects only to the side of the switch that will relate to A14/15/16. I'm not sure if mixing/using it with the chassis ground will affect anything. I believe digital stuff tends to be fussy when it comes to grounds, and I can remember if Vss comms with the chassis ground too. Use the chassis to ground your LED's instead, just in case.
This is what I think, but Greg will chirp in to correct me if I'm wrong. He's been around the block a few times with these builds.
Everything else reads correct to my eyes. The diagram in the build doc is pretty clear, but if there's anything that can be improved, don't be shy to point it out. The document, as is life, is always a work in progress. :icon_wink:
Dead End FX
slacker775
The VSS stuff did sound fishy to me, but I think the way it's worded in the doc may be unclear.   For chassis ground, there is a pin off the adapter that I should be able to use then if I'm not mistaken.
digi2t
Quote from: slacker775 on May 27, 2015, 06:49:14 AM
If you could, please PM me the offending wording, and I'll see to clarifying (to the best of my abilities).
Cheers.
Dead End FX
the3secondrule
Admittedly, I haven't read this whole thread, but I've searched and can't find an answer:
Is there any sub for the J113 jfet? I think it's the only thing that I am missing. If it's used for switching then I assume a j201, 2n5457, or 2sk30a should be ok?
"Rock music is mostly about moving big black boxes from one side of town to the other in the back of your car."
Govmnt_Lacky
Quote from: the3secondrule on May 30, 2015, 08:36:42 PM
I have only used the J113 so I could not say. They are still in production and are very easy to come by.
If you need any, PM me here or at MBP and I 'll see what I can do  ;)
the3secondrule
Quote from: Govmnt_Lacky on May 30, 2015, 08:45:28 PM
Thanks man,
If I can't find a local solution, I'll hit you up! I'm in New Zealand, but I don't imagine postage on a couple of FETs will kill me ;)
J
slacker775
I got mine from mklec on eBay.  Not sure how their shipping to NZ might be.
the3secondrule
$20 shipping on $5 worth of FETs from Mklec...
Lost of cheaper options on the bay though.
digi2t
Check Nightfire Electronics. They stock them, and I think the shipping might be more reasonable. Choose a quantity for the cart, fill out your shipping info, and scroll down to the "Click to calculate shipping" button.
Dead End FX
the3secondrule
Thanks Dino,
Shipping from Nightfire was much more reasonable
J
