Sunface Board clean adjustment knob
Started by Easywider, June 10, 2007, 03:37:44 PM
Easywider
Received a board from Mike & just had a question . board is set up for the clean adjustment knob . was wondering if the circuit would work without one . can i just leave it out , or should i run jumper wires !
Thanks ,
Chris
  Hopefully someone just knows the details one would need to know to figure that out?
  Makes me curious what the pot described as 'clean adj. knob' actually does.
Easywider
Just bumping this one up , wondering if someone can help me !
Thanks ,
Chris
  Yes, set the knob where you want it.
  Read the resistance[s that pot provided at that setting.
  Replace the resistance[s?] the pot provided at that setting with fixed resistors.
  Let me ask the 8 ball...ok it say's 'not very likely' [I had to shake it a few times].
hairyandy
Quote from: petemoore on June 11, 2007, 10:09:28 AM
Damn you Pete!  I just sprayed milk and Honey Nut Cheerios all over my laptop...that was brilliant.
Andy
Andy Harrison
It's all about signal flow...
Hairyandy's Layout Gallery
analogmike
My 8 ball says just hook the input wire up to the wiper of where the trim pot would go :)
Easier than running a jumper.
Have fun!
DIY has unpleasant realities, such as that an operating soldering iron has two ends differing markedly in the degree of comfort with which they can be grasped. - J. Smith
mike  ~^v^~ aNaLoG.MaN ~^v^~   vintage guitar effects
http://www.analogman.com
Easywider
Mike , Still trying to make 'er work..... just making sure of where the trimpot wiper pad is located on the sunface board, having problems with Q1's voltage , & wonder if this might have something to do with it !
Thanks ,
Chris
Electric Warrior
what exactly is the clean adjustment knob?
Easywider
just bumping this one up , wondering if anyone can help !  ;D
Thanks ,
Chris
