Troubleshooting a rebote 2
Started by spiderman2812, June 11, 2007, 05:38:37 AM
spiderman2812
What would make a rebote 2 kind of self oscillate or go all over the place? It has been modded to do the endless repeats and has worked fine and then all of a sudden it just started doing this. Anyone have any suggestions?
bioroids
It would help us indentifying the problem if you could be a little more specific on how and when (control settings)  the pedal is misbehaving.
I think you may have a broken wire/bad solder joint/broken pcb track around the repeats potentiometer.
luck!
Miguel
Eramos tan pobres!
ruispeeds
Hi there,
you also should try to chek the repeat  resistor you have changed, once i had the same problem and try with a 12k resistor and it worked fine.
good luck
Rui.
