testing Ge trannies
Started by Bagge, June 18, 2007, 10:50:22 AM
Bagge
I'm building a booster with a Ge tranny (AC187K). I couldn't bias it properly at first. On a tiny movement, it went from 1 v to 9 v at collector. So I build a tester using Smallbears explanation. I don't quite understand the readings, I get. So I thought they might be reversed. Is the red dot always on collector side? And have anyone had experience with reversing AC187K? (I know some devices can be reversed)
zjokka
Try maybe a smaller value trimpot first.
If you bought a tested transistor, it should bias ok.
