|AMPAGE| |GEOFEX| |AMZ|
May 24, 2013, 10:25:42 AM
891795 Posts in 97631 Topics by 28706 Members
Latest Member: originalnemo
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  Low gate voltage on MOSFET booster? 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: 1 [2] Go Down Print
Author Topic: Low gate voltage on MOSFET booster?  (Read 677 times)
thelonious
Tristan
Re: Low gate voltage on MOSFET booster?
« Reply #20 on: March 06, 2013, 10:45:51 AM »
Will do. That idea made me go read more about bypass caps, too---thanks for the motivation. I knew they increased the output of a stage by reducing/eliminating negative feedback at the cathode/source/emitter, but for some reason I never put it together that that less negative feedback at the source = more input gain within the same stage, and more NFB = lower gain in that stage... cool.
Logged
« Reply #21 on: March 07, 2013, 08:59:43 AM »
you could try replacing r1 and r2 with 33k each, with a 100k trimpot between them connected to r3/c3. then you could shift the bias point of the mosfet while watching the cro to get the maximum swing from your particular device. I'm surprised this hasn't already been suggested.
Logged
hindsight. now why didn't I think of that earlier?
Pages: 1 [2] Go Up Print
« previous next »
Jump to:
