My Random Number Generator Layout
Started by mattpocket, June 29, 2007, 08:01:57 AM
mattpocket
The fact that the tranny legs for Q3 and Q4 are bent means the layout can be more compact. And could go even smaller. I just spread it out a bit for now. Of course you could put the trannys in straight if you were going to use a feedback pot, rather than a resistor, but my layout allows for both. Whether its correct or not is a different matter.
Can anyone check it for me? I know a couple of people were interested in a layout for this!?
Matt
Built: LofoMofo, Dist+, Active AB Box, GGG 4 Channel Mixer, ROG Omega
On the Bench:Random Number Generator, ROG Multi-face, Speak & Spell
My Pop-Punk Band - www.myspace.com/stashpocket
ambulancevoice
what happened to the 1M resistor from q1 collector to q2 base?
other than that it looks good to me
smnm
the designer is Doug Deeper /mid-fi electronics
mattpocket
Cheers. I have been away, so I will add that stuff in asap.
Thanks guys!
dr.benway
First off, sorry to bother Matt Pocket and Ambulance Voice with the same message as a personal mail but I just finally noticed the reply button that allows posting.
So, regarding Matt's layout, two questions :
Does the missing 1M resistor go directly from the collector of Q1 to the base of Q2 ?
Can I pop it in on the back of the board or with a jumper ? I've already populated and soldered and it's a tight and messy fit.
Thanks for your help
ambulancevoice
dr.benway
ok thanks.
finally got it working using your layout to perfboard matt, thanks !
took me some time, but I think that's mainly because I'm an electronics illiterate :
I got thrown off by the trace from R5 to C4, thinking it was connected to the base of Q3 (If only I'd looked at the schematic sooner!), as well as the hole next to R8.
Asarge519
Hey everyone, I'm new to the site. I know this is an old thread but I was wondering what would have to be changed in order to run this off a 9v power supply? Just the plug instead of a battery and a cap across that or more? thanks
anchovie
No harm in putting a 100uF filter cap between 9V and ground, just in case your PSU doesn't already have filtering. If you want polarity protection, put a diode in series like this:
PSU positive ----------|>|----------- Effect 9V
                                          == 100uF
PSU negative ------------------------ Effect ground
