Behringer GDI 21 SIMPLE-Boost-Mods
Started by snyder80, July 02, 2007, 12:55:57 PM
snyder80
Maybe this aint no news for some readers, but there is a dead-easy mod, that enhances the tonal variation (not realy the quality, though it could sound better through your amp, dunno):
You can have
1. A British mode, that is much more cleaner und not that compressed, by twiddling the AMP selector inbetween the tweed and british mode. So when u use the britisch modified mode, it gives you some sort of boost to the stock and compressed british mode. If u like the sound, open the back and solder 2 wires to bottom LEFT pinouts from the AMP-switch and the two other lugs to a jack with a switching option. That way the "boost" can be footcontrolled.
2. A real boosting option for all the three Sound-modes:
Twiddle the MOD-selctor in between the CLN and HI G-mode. It sounds much more open and loder than the HI-G (as the CLN MODE is, too).If u want it to be footswitchable, solder two wires to the bottom RIGHT pinouts of the MOD-selector and to a jack with swithing option like mentioned above.
Hope that helps someone....
PS: Maybe someone know some other "hotspots" to maybe add a Mid-Poti or other mods ... (best would be to get rid of the british harshness)
alex frias
Oh, Gosh...
You are the StratPickupSwitcherManiacUpToThePedal?
Pagan and happy!
snyder80
#2
no, why do you ask for ???
By the way, it realy sounds fuller and more open on this clone.
Maybe it works on the original Sansamp GT2 - and could already be a well known "Mod"
teddybear
alex frias
Well, I've just tested it and... CONGRATULATIONS!!!
It works just the way you described it.
Ingenuous.
Pagan and happy!
snyder80
@ alex frias
Nice that you like it. Its realy simple but give more fun...
@ teddybeer  ;D
Well i cant find a way to up the pics in the reply. So here is a diagram thing and how to:
just unsrew the backplate. No need to get the pcb out of the box.
The board looks like this  ----------------------------------
                                     I                                         I
                                     I                                         I
                                     I    G     M       M        A        I
                                     I    N      I        O        M       I
                                     I    D     C        D        P        I
                                     I________________________I
Except for the griundlift each "selector" has a horizontal switch with 8!! legs and looks like this:
*1           *5
*2           *6
*3           *7
*4           *8
For Mod1 get a cable from *3 to *4 or at any spdt/dpdt switch  with *3 to the middle and *4 to the upper or lower pin on the switch
#------>NOTHING
#-----> Pin *3
#------>Pin *4
or to a simple Linejack:
                  /  I              I
                /    I              I
              /      I              I
           *3      I              I
    normally     I________I
     Ground           I
                          I
                         *4 (usuallay Signal/TIP on jacks)
For the Boost-Mod just use *7 and *8 from the Mod-Switching-Back instead of ITS *3 and *4. Everything else is the same. Maybe you might add a pulldown resistor against a short ceackle when switching from the NewBritish-Mod to the original one. Also you have the same sound for new british even if u are in Tweed or british. Sad that it doesnt work in Califrnian mode too, but maybe tweakable....
Hope that helped u...
