GOLDEN DRAGON OVERDRIVE ( A REWORK OF THE MINIBOOSTER)
Started by Dragonfly, July 07, 2007, 04:42:53 PM
Dragonfly
Inspired by Jack Orman, I decided to go back and revisit the National Semiconductor "Ultra High Gain Audio Amplifier" circuit, and see if I could tweak it into a nice overdrive. The result is a cool low / med gainer that is easy to build, and can even be built on one of Jacks boards, available at www.muzique.com
Like Jacks Minibooster, pretty much every part value is different from the original...and the values are also different from the Minibooster !
Sometimes its nice to go back to your roots and see if you can tweak things...
If you're in the mood to put together a quick and easy build, this one is a cool one. Depending on your amp / guitar setup, you may want to adjust the value of the .001uf cap to ground at the end of the circuit. Also, if using Jacks boards, i would assume (I havent seen his layout) that you'd need to attach the 10uf cap directly to the GAIN pot, and the .001uf cap directly to the VOLUME pot.
Have fun, build, tweak away. :)
markm
Sounds Good Andy!!
Nice to see ya around here more again!  :)
I've always liked the Mini-Booster as well and the thought of putting a Gain Control on it Never occurred to me!
Don't know why but, it never did.
Is the Gained "dimed" on it in the clips?
If not, I'll bet it can do a Great Mild OD huh?
Nice to have ya back around these parts!!  :icon_wink:
QSQCaito
:D it sounds cool ;)
Thanks a lot.
EDIT: Why do you start with an already distorted signal, insetad of a clean one.. is it just taste?
D.A.C
markm
Quote from: QSQCaito on July 07, 2007, 05:50:34 PM
"Clean" is such a subjective term.
Almost as much as "Grit", "Sparkle", "overdrive".
Hell, one guy's overdrive is another's distortion! Those are known as "Stompbox Grey areas!"  ;)
QSQCaito
Quote from: markm on July 07, 2007, 06:01:36 PM
I know the grey area. With distorted I meant it's not coming as brouhht to life by the pickups, which would be a clean sound.
Distorted not for amount(grit spark, overdirce fuzz etc..), but for ir being modified.
D.A.C
markm
I see what you mean.
Yeah, on a second listen, it's definately gritty before the effect is engaged.
Dragonfly
it was just the sound that came up when i turned on Gearbox. I didnt mess with it.
the sound is "fairly" clean...but seriously, a large degree of people use overdrive to "add to" a slightly gritty signal, so its a good representation of the overdrive in use.
to each their own.
markm
Quote from: markm on July 07, 2007, 05:44:49 PM
Dragonfly
Quote from: markm on July 07, 2007, 08:00:44 PM
In the clips the gain is "near dimed" :)
It is REALLY good as a mild OD...something your Country-Luvin' chops will dig !  :D
and thanks...it goes in waves...sometimes I have the urge to be here, sometimes I dont...right now I have the urge....  ;)
tcobretti
Another nice one, Andy.  I really like the way it is similar to the minibooster - very cool idea.
Yeah, I never run my guitar amp completely clean, even when faking jazz.  With a good amp, you can clean it up almost all the way just by playing more lightly.
Dragonfly
Quote from: tcobretti on July 07, 2007, 09:24:40 PM
thanks...Jacks was a adapted version of the original, and mine is an adapted version of Jacks ! :D
Thats the way I run things on my amps as well.
John Lyons
That does sound good. Sounds like it responds to light picking as well as harder clipping if you dig in.
Nice one!
John
Basic Audio Pedals
www.basicaudio.net/
jlullo
yes that definitely sounds like it would clean up NICELY to a light overdrive!
good job as usual AC!
i also second the motion that it is nice to have you around here a bit more ;)
markm
Quote from: Dragonfly on July 07, 2007, 09:20:33 PM
That's kinda what I was thinking!
It sounded as though to me if that baby was dimed, it was a circuit for Country for sure!!
Thanks AC!!
BMF Effects
Sounds very good. Reminds me of the Mike Ness/Social Distortion tone.
