BBE Green Screamer Overdrive Schematic
Started by wampcat1, July 09, 2007, 01:57:02 AM
ulysses
the sound quality of the demos on their website is so appauling it hard to tell what it really sounds like..
cheers
ulysses
wampcat1
I haven't heard the soundclip, but it is just a bufferless tubescreamer type circuit with less gain.
nothing new.  :icon_mrgreen:
bioroids
I think a resistor may be missing from the non-inverting input of the first opamp to Vref, or does it use a bipolar supply?
Regards
Miguel
Eramos tan pobres!
Paul Marossy
Quoteit is just a bufferless tubescreamer type circuit with less gain.
So is it more like a dirty booster pedal then?
Paul Marossy
RGW
I think R6 should be
a) on the other side of the input cap
and
b) connected to +4.5VDC versus ground
take care,
Robbie Wallace
wampcat1
Quote from: bioroids on July 09, 2007, 08:23:59 PM
Regards
Miguel
yes, the bias resistor isn't there, but I figured most people would know that one was needed. Throw a 10k in there and you'll be fine.
bw
wampcat1
Quote from: RGW on July 09, 2007, 09:17:10 PM
and
------------------same thing basically
--------------nope, it's ground
take care,
Robbie Wallace
RGW
Quote from: wampcat1 on July 09, 2007, 09:44:40 PM
bw
If you do that with no input buffer, the input impedance will be around 10K, which is way too low.
take care,
Robbie
RGW
#10
Quote from: wampcat1 on July 09, 2007, 09:47:01 PM
and
Which side of the input cap it is on makes a big difference. If it is on the input side and going to ground, it is probably a pulldown resistor. If it is on the output side of the cap and connected to the +4.5VDC bias it is setting the input impedance of the circuit and supplying DC bias to the opamp.
take care,
Robbie
wampcat1
Quote from: RGW on July 09, 2007, 10:06:53 PM
and
take care,
Robbie
sorry, I misunderstood you... I thought you meant r6 should've been before c3.
r6 is just for the bypass pop.
bw
wampcat1
#12
Quote from: RGW on July 09, 2007, 10:00:53 PM
bw
take care,
Robbie
yep, sorry I was just thinking of the tubescreamer circuit.... throw a 470k to 1meg in and you'll be fine then...pretty common value there. :)
RGW
Thanks for sharing the schematic, it is time consuming tracing circuits, drawing it out, etc. That is cool of you to take the time and share it.
take care,
Robbie
Paul Marossy
#14
I drew up my own schematic for this circuit today as I'm going to be modding one.
Just to make some clarifications/additions/corrections to the schematic above:
1. The 1K input resistor is R5, not R6
2. R6 is a 10M resistor to ground, not a 1M (it is indeed a pulldown resistor)
3. There is a 1M resistor, R4, connected between the Pin 3 of the opamp and Vref
4. There is a 10K voltage divider, R2 & R3, for the Vref supply
5. There is a Vref cap, C2, which is a 10uF polarized type
6. There is a 100pF cap, C5, in parallel with diodes D3 & D4
7. There is a 1K resistor, R12, between C9 and the 10K level control
8. Gain control is VR1, Tone control is VR2 and Level control is VR3
9. The main power filter cap is C1, and is 1000uF (!)
10. The output cap, C9, is a 1uf non-polarized electrolytic type
