anyone got any 1ohm 1% 1watt resistors in australia?
Started by ulysses, July 25, 2007, 10:32:44 PM
ulysses
hey guys
does anyone know of a store in sydney that sells 1ohm 1% 1watt metal oxide resistors in australia?
i need two of them to bias the tubes in my amp and i dont really want to have to pay a $29USD fedex fee for a couple of 50c resistors :)
maybe someone would be kind enough to send me a couple via auspost? - paul is this the type of thing you keep on hand?  ;)
cheers
ulysses
the_random_hero
Grab a pack of 8 carbon films from Jaycar and use your DMM to see which is closest to 1 ohm.
Completed Projects - Modded DS1, The Stiffy, Toaster Ruby, Octobooster Mk. II, Pedal Power Supply
ulysses
yeah i was thinking of doing this - i actually bought a pack of 2 1ohm 1watts from jaycar last time i was in there - they were both 1.1ohm - i would have tested in store but they were plastic sealed.. looks like ill have to go back with my pointy ended multimeter probes :) poke my way through the plastic :)
cheers
ulysses
ecua
ulysses
Quote from: ecua on July 26, 2007, 12:42:02 AM
any possibility of paralleling the resistors?
not really feasable as its quite tight hanging off the power tube socket to ground. besides i think it would be messy to have two where only 1 was required.  ;)
cheers
ulysses
Paul Perry (Frostwave)
Selecting with a multimeter is OK if you are 100% sure your meter is much better than 1%.
ARE you 100% sure? :icon_rolleyes:
Shakal
I guess 100% is impossible... maybe 99%.
But the 1% are precision, they shoudn't ever has 1.1Ohm instead of 1Ohm... Why is that?
In Australia, the cheapest 1 ohm 1% resistor, is made by putting ten 10 ohm 1% metal film in parallel.
The 10 ohm is the smallest 1% metal film Jaycar carry (in packs of 8, for your inconvenience :icon_mad: )
Not to diss jaycar, we'd be stuffed without them!
the_random_hero
Quote from: Paul Perry (Frostwave) on July 27, 2007, 09:38:37 AM
Wouldn't all those little manufacturing inconsistencies start adding up then? My opinion on Jaycar has greatly improved in the last day or two, I managed to become a registered business with them so I get trade discount. The guy who served me also builds stompboxes and was pretty cool.
ulysses
Quote from: Paul Perry (Frostwave) on July 26, 2007, 09:01:38 PM
well its a fluke so i should hope so!
it is much quicker and much more stable at deciciding what value a part is - my old multimeter would stuff around for about a second with values going all over the place, it would then fluctuate more than i liked.
cheers
ulysses
ulysses
Quote from: the_random_hero on July 27, 2007, 05:04:38 PM
i can pick a lot of holes in jaycar's parts selection. i presume its mainly profit motivated - but they claim to want to provide the best parts available - i am constantly having to order from other electronics stores in aust and overseas.
cheers
ulysses
So far as tolerances go - if you connect 1% resistors together in any pattern at all, the result is within 1% of the theory.
Some people could prove that mathematically for ALL cases, but even I canprove it for the parallel & series case (well, for small N  :icon_smile: ).
As for Jaycar, they have chosen to try to sell electronic stuff to the masses. Unfortunately, the number of people who think tricked up cars & fart machines are cool, far exceeds the numbers of FX DIYers. And the stock range reflects this. Building FX takes a bit of planning. And, some parts are goijng to have to come from overseas - but at least if you get them from Steve at SmallBear, or your switches from Aron, there won't be a fedex charge.
ulysses
Quote from: Paul Perry (Frostwave) on July 27, 2007, 09:05:56 PM
i went into jaycar the other day - the latest gadget on the counter was a stripper that sang and danced up and down and around a pole to porn music - "ill take some resistors and the dancing stripper thanks"
cheers
ulysses
the_random_hero
I've just been ordering 3PDT's from eBay at the moment - $10 each for CIC-branded switches, which isn't too bad I guess. While I've got some money to blow, I ordered a heap of stuff in bulk, so that should keep me going for quite a few more builds.
