True Bypass Strip
Started by Higgie, July 31, 2007, 11:36:50 PM
Higgie
Hey guys,
I'm thinking of building my own true bypass strip, and there's a certain mod I would like to do, but I don't know how to do it.
I am going to have 5 loops, a master bypass, and a tuner out.
The mod I would like consists of this: A single toggle-switch that would reverse the signal chain of loops 4 and 5, so that I can change wether the signal chain goes loop 3 into 4 into 5, OR loop 3 into 5 into 4.
Would anyone be kind enough to draw up a rough wiring design of the pedal for me?
Cheers,
James.
tranceracer
wire up the juggler ckt between effects 4 & 5
http://www.geofex.com/
11/04/99      the Juggler, a foot-stompable effects order reverser.
Processaurus
not about the reverse switching, but pedal parts plus sells drilled out, painted 5 loop strips, that's quite the niche product!
http://pedalpartsplus.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=PPP&Category_Code=ENC14
Higgie
Quote from: Processaurus on August 01, 2007, 10:47:06 PM
The only problem with that is that it is too small for 7 footswitches. I need 7 because of the Master Bypass and Tuner Out, in addition to the 5 loops.
CGDARK
Quote from: Higgie on August 03, 2007, 07:57:18 PM
Why not build one strip with five loops and another one for the Master Bypass and Tuner Out? ;)
CG
jakenold
How about putting a buffer on the output of the strip, to feed your amp AND the tuner at the same time?
That way, your signal is not loaded by the cable to your amplifier, and you don't have to cram 7 switches into the enclosure.
mfg Jake
Gilles C
