Switching Noise with LEDs Connected to AC?
Started by chrisaxeman, August 02, 2007, 08:49:31 AM
chrisaxeman
Hi,
Haven't posted for a while and found little in the search function..........
Building a power supply for a rack guy with all 9 VAC outlets.
I want to connect LED's for indication on these 9 VAC taps(trying to avoid rectifying and filtering to DC just to run LEDS),but I'm worried about inducing switching noise back into the audio.
I've seen the anti-parallel setup with the second diode,but is it possible to place some caps somewhere in circuit to avoid potential switching noise caused by the LED and diode setup dropping in and out on the cross-over points?
Cheers in advance.
Chris......
I have no idea what I'm doing,but I like the way it sounds!
chrisaxeman
