Tremulus Lune VERO layout
Started by Gila_Crisis, August 08, 2007, 06:46:52 PM
Gila_Crisis
hi,
i've done a vero layout for the tremulus lune, which is based on the one made by torchy but is adapted for the last Rev.2.4.1. that you can find on commonsound (this: http://commonsound.org/tremulus/pcb2.4.1/schematic.pdf ).
N.B.: i didn't draw the LFO Led and the two 1k resistors that goes together with it (R12 & R16), since this is a feature i don't care about. is it right to leave them away like that or do i need a 2k resistor that goes from pin 1/2 of the 4558 to ground?
N.B.2: It would be nice if some one can check it out for errors.
here you go:
ENJOY  :icon_mrgreen: :icon_mrgreen: :icon_mrgreen:
Gila_Crisis
pay attention, i made some little changes, here it's the new one:
~arph
Nice, I like the way the LFO and audio section are separated. I think I might check it out tonight.
Hanglow
Hi, has anyone tried this one out?
Good effort by the way, I was tempted to get the pcb for this as I liked the phaseur fleur a lot, but might try this vero layout instead.
Looking at the schem, it would be quite easy to add the symmetry pot wouldn't it?
Gila_Crisis
hi, the simmytry is simply a pot wired around the speed pot, so you don't need extra components on the pcb.
i' haven't cheecked it yet, but there's also this vero layout (on which i based mine) which works for shure
http://i197.photobucket.com/albums/aa131/veroboard/Tremulus_Vero.gif
the schem for this layout is this one:
http://i12.tinypic.com/4qeduzc.jpg
Hanglow
Ok cheers, I hadn't seen that one before
Valoosj
Quote from: Gila_Crisis on August 13, 2007, 01:47:42 PM
Cool!
Is there one with the symmetry on it as well? I have been looking for one with a PCB layout, I can't find the image to make a pcb
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
kurtlives
Has this been verified?
Does anyone have a copy of Torchy's Lune layout?
My DIY site:
www.pdfelectronics.com
kurtlives
A layout with no values or labelling! Thanks but I already found that, kinda useless.
My DIY site:
Thomas3D
Yeah, you would have to kinda use the schem at tonepad.com to figure it out..
Gila_Crisis
hi, the layout above is verified. actually is based on torchy's layout, i just changed some values to match the last revision of the schem found on http://www.commonsound.com/ this one: http://commonsound.org/tremulus/pcb2.4.1/schematic.pdf
