Tim Escobedo's Q &D Question
Started by Baktown, September 10, 2007, 09:19:18 PM
Baktown
All,
On the vero layout and schematic for Tim Escobedo's Q & D, there's a CV input.  What does CV stand for?
Thanks,
Axl Bundy
widdly
It stands for Control Voltage.  It refers to a varying voltage source used to modulate a parameter, in this case the filter cutoff.  It can be as simple as the center tap of a pot wired between V+ and gnd or something more complicated like a vanishing point sequencer.
Baktown
Thanks for the info, but I'm still confused!  I'm a rank beginner here, so bare with me.
For the purposes of this build, what should I do?
Axl
widdly
 There is already a frequency knob and a resonance knob there so you can control the filter with those.
You can leave off the CV in all together.  The effect will work fine if don't connect anything there. It's an option so that later on you could add say an expression pedal to the effect.
Baktown
Cool!  I think I understand now.  One last question:  I really like the "reverse" sound this pedal gets as heard on the sound file, will I need a CV source to accomplish this sound?
Thanks,
Axl
widdly
I'm not sure which sound file you are talking about.  I couldn't see any Q&D samples on Tim's website
Baktown
MartyMart
That sound sample is the Q&D compressor, not Tim's VCF !!
It uses the SSM 2166 chip, for comp/limit/gate/boost using minimal components.
MM.
Baktown
OK!
Thanks for the clarification.
Axl
