trebley Boss DD-6
Started by Nuts, September 16, 2007, 04:50:14 PM
Nuts
Hi,
Is there any mod to the DD-6, like the DD-3's high cut mod ?
that's really necessary, I hope someone have a clue.
Thanks,
Nuts.
  There is, I've read about it...don't know where.
  I asked the same question here about a month ago, NR.
  I would say trace the signal to where it's about to come out [just before bypass] and tame it there. You want any treble rolloff to not affect bypassed signal, a small value cap from signal path to ground.
  I had one for a few weeks, and did notice the treble 'grew' alot when the repeats...when the echoes were turned up, IME unacceptable levels of HF which then distorted.
  The other way in which this could be done is at the 'recycle' input...where the echo goes back to pre-echo to be echoed again, or echo feed [daft terminology], so that only the echoes and repeats get the filtering, and successive repeats would then be increasingly less trebly....kinda more like 'real life'...not sure what it looks like in there.
  I opted back to Echo Park...only thing I really miss on the DD6 is the warp mod, which was just too warpy, actually worked really cool [if it's just 'fanned' ..held on for transient periods] but couldd'a been set to be less or adjustable IMO.
