(Nearly) Complete LXH2 Full PCB
Started by GuitarLord5000, September 26, 2007, 11:33:37 PM
GuitarLord5000
If anyone's interested, I have finally completed the LXH2 PCB in its entirety.  Since Im using DIY Layout Creator, the circuit is WAY too big for the program, so I divided the PCB up into modules consisting of:
1. The Marshall Amp Sim
2. The Cabinet Emulator
3. The Peak MFB Filters
4. The Dip MFB Filters
And here they are:
Amp Sim:
Cab Sim:
Peak Filters:
Dip Filters:
If anyone can see any mistakes, let me know, and I'll fix it.  Also, if anyone decides to verify this PCB, PLEASE let me know.  Just as soon as I can figure out how, I'll be uploading these PCB's to the DIY Layout Creator site.
The only thing that is really missing at this point is the +/- 9v power supply.  If anyone has a PCB for this or would like to throw one together to really complete this project, please post it here.
The schematic is here:
http://home3.netcarrier.com/~lxh2/marsh.html
Life is like a box of chocolates.  You give it to your girlfriend and she eats up the best pieces and throws the rest away.
km-r
some effort dude! kudos!
it looks complicated to me though as i always prefered the lxh2 using DUAL op amps... so the pcb was a lot "linear" and quite easy to trace problems [if any]
now you just need someone to verify your work...
Look at it this way- everyone rags on air guitar here because everyone can play guitar.  If we were on a lawn mower forum, air guitar would be okay and they would ridicule air mowing.
jrc4558
guitarLord, man, check you email, I sent you what you asked several days ago.
GuitarLord5000
Quote from: km-r on September 26, 2007, 11:47:14 PM
Wow km-r, I couldn't even fathom trying to do this project with Dual Opamps!  That would be a WHOLE lot of packages and supply rails to deal with.
Quote from: Constantin Necrasov on September 27, 2007, 12:22:06 AM
Constantin, I looked over your Fender LXH2, and I have to say, it's a shame that it didnt work for you.  Its a beautiful piece of work!  When I first started designing the Marshall PCB, I attempted to line all the Opamp packages up down the middle like you did (it makes putting the supply rails in VERY easy!)  But I just couldnt do it, as the Marshall sim has too many opamps.  I also worried that putting the + and - rails that close together might introduce a lot of noise.  If I ever get the gumption, I'll probably do the fender sim.  But after finishing this one, I've lost a lot of the drive to do PCB's of this complexity.  Im probably not even gonna do this project for a while, as Im tired of looking at it already!
BTW, guys, How exactly do you power your LXH2's?  Are you using a transformer to give you +/- 9v or are you able to use the Max1044 chip?
MetalGuy
km-r
Quote from: GuitarLord5000 on September 27, 2007, 02:10:25 PM
indeed dude, and for the other reason that i have tons of dual op amps around...
i placed it in a large enclosure together with a +/- 12V supply regulated down to 9V using 7809 and 7909...
kusi
MartyMart
Great effort and no wonder that you want to get away from it for a while !!
I did mine on veroboard - without the spkr sim and it was a beast to do, but I only had a
10 minute de-bug !! :D
Tried it out again a week or so ago and it sounded most excellent .. MM
MetalGuy
Quotemy versions;
Schematic
TopLayer
BottomLayer
mfg kusi
Good job but I can't help to make a note. Double layer PCBs are not DIY projects friendly. Personally I never design double layer PCBs and skip automatically any projects containing such but in this case it's not fatal.
GuitarLord5000
Quote from: MartyMart on September 29, 2007, 01:56:24 PM
Wow, a 10 minute debug.  Most Excellent!
So how do you power YOURS Marty?
I'm curious because i've never messed with anything other than 9v stompbox power supplies.  Messing with transformers is something that I really dont wanna get into at this point.
I dont think the Max1044 would have enough ass to power all these opamps.  Does anyone agree?  Disagree?
Are there any +/- 12 volt wall warts available?
rody82
GuitarLord5000
Quote from: rody82 on September 30, 2007, 03:30:02 PM
What about building a simple +- 9 V power supply?
There's a project at ggg.
http://www.generalguitargadgets.com/pdf/ggg_bipolar_ps.pdf
Yeah, I'd seen that.  But....
Quote from: GuitarLord5000 on September 29, 2007, 05:42:56 PM
Unless of course, there are no other options.
GuitarLord5000
Oh, and a big thank you to you rody, for attempting to verify this for me.  From the mistake you found, I have generated this:
Thanks again!
MartyMart
I simply used 2 x 9v batteries, one on input jack and reversed on output jack ( craig anderton style )
It's lasted several hours and is still going strong, PSU is a better solution and 12v/15v will offer more
lower gain headroom I think.
MM.
rody82
Finally got some parts today, and built the power supply. (based on ggg bipolar project).
What bothers me, is that i have exactly 9V on the + output, but only -8.77 on the -.
The 7909 was made by another manufacturer (it was labeled with an S, and CZ on the bottom right corner).
I ordered 2 of them, so i soldered in the other one, but got the same result.
Will this have a negative effect on the sound? Should i buy some quality 7909?
thanks,
Rody
rody82
And it seems they have output voltage tolerance of about 4%...  :icon_sad:
I used a 150ma 12V transformer.
MetalGuy
QuoteAnd it seems they have output voltage tolerance of about 4%...
This difference is normal and can be even bigger. I'm using mainly 7812 and 7912 regulators and I never get exactly + or - 12V out of them no matter of the manufacturer. The 7812 usually produces 11.8V the 7912 -12.2V but that's not a problem and it's not fatal at all.
rody82
ok then, i'll try it. If it sounds good then i wont care.
Got some new regulators though :)
rody82
What did you use for C1? A ceramic or a film cap?
GuitarLord: That trimpot location could be improved. The bottom 2 legs were ok, but the top leg was way more far away, at least + 2 holes. It seems trims here in europe are so big. :)
I've built the first section, still waiting for my pots to arrive, and could not decide what to use for C1...
GuitarLord5000
Quote from: rody82 on October 14, 2007, 01:44:34 PM
Wow!
Sorry rody!
When I designed the PCB, I did it based on the trimpots found at smallbear.  While they are somewhat physically large, the lugs are very compact.  They are really great trimpots!  The truth is, trimpot sizes vary so much, there's no way I could possibly account for all of them.  I chose the smallbear model because smallbear is widely used amongst folks from this forum.  I guess that anyone building this particular project would either have to purchase from Steve at smallbear, or else modify the .DIY file to suit the trimpot that they have available.
Keep us posted on how the build comes out.
And thanks again for verifying the project!
Dave
