Tonepad Ross Compressor shorts out, Why?
Started by F2HF2H, October 02, 2007, 10:41:01 AM
F2HF2H
Hey :)
I built the Ross compressor and it worked great.
I sent it to my friend wrapped firmly in bubble wrap, and when he plugged it in it didn't work.
When I took it back, and started  looking for the problem i found some things:
When i plug a battery or a transformer in- they begin to heat up as if there was a short.
The Resistancy reading of the 4.7M resistor near the input shows 0.2  OHM!
If it worked and suddenly doesn't.. what could have gone wrong?
Thanks,
Shachar.
A cat and a dog chattin':
Cat: "Dog, do you want to know how i caught the mouse?"
Dog: "how how"
Papa_lazerous
I would say what happened is obvious, it got damaged in transit or your friend screwed it.  Whats probably more important now is fixing it  :icon_wink:
stumper1
Did your freind use a power supply?  If so, what kind?  Check the diode that goes from +9vdc to ground.
What layout did you use?
Deric®
F2HF2H
Quote from: Papa_lazerous on October 02, 2007, 02:18:37 PM
hehe  ;D
he didn't screw it.. i know him, he knows what he's doing.
i don't think that it got damaged in transit.. i wrapped it in 3 inches of bubble wrap  :icon_lol:
Quote from: stumper1 on October 02, 2007, 03:21:47 PM
i used the Ross Compressor layout from www.tonepad.com
what sould i check about the diode?
he used a power supply- a 9v, 800mah transformer.
he said the transformer got pretty hot..
afterwards he used a 9v battery..
Dog: "how how"
F2HF2H
OH MY GOD.
I replaced the diode.
IT W-O-R-K-S!
How did you know it's the diode?
Thank You!!!!!!!!!!!!!!!!!
Dog: "how how"
Papa_lazerous
it must have been fried by reverse voltage.....maybe your mate did screw it ;)
F2HF2H
Quote from: Papa_lazerous on October 02, 2007, 04:55:36 PM
hehe.. :)
umm.. another question:
the effect is a little noisy.. any tips? :)
(it's in a metal box)
Dog: "how how"
stumper1
Quotehe used a power supply- a 9v, 800mah transformer
My guess would be that he used a 9vac power supply instead of 9vdc.  That would explain the bad diode.
Deric®
F2HF2H
Quote from: stumper1 on October 02, 2007, 05:57:16 PM
he did..  :icon_redface: :icon_redface: :icon_redface:
but the weird part is, that his roland keyboard and Yamaha DI-100 worked with this..  :icon_biggrin:
nvm now, thanks! :)
Dog: "how how"
F2HF2H
Dog: "how how"
Papa_lazerous
Quote from: F2HF2H on October 02, 2007, 05:03:28 PM
hehe.. :)
Its a compressor its going to be a bit noisy thats the nature of the beast.
If you are using the stock compressor layout then there are plenty of tweaks to quieten it down just have a search this pedal has plenty of posts against it
F2HF2H
Quote from: Papa_lazerous on October 02, 2007, 06:40:33 PM
hehe.. :)
well, i searched for over an hour with no results..
does anyone have any mod to quiet it down a little?
Dog: "how how"
Papa_lazerous
PM me and I will go through some ofit with you rather than go wayyyy off topic on here.
PS there are posts, the trick is how you search ;)
