GT2 - mod DarkAngel - DIY Layout Creator
Started by ANDYEFFECT, October 11, 2007, 07:15:55 AM
ANDYEFFECT
I have interest in pcb of the GT2 mod DarkAngel;
where I can find pcb of DIY Layout Creator?
grateful
andre
schematic GT2 correct
bancika
I don't have it in the gallery click here
Maybe someone made it  :icon_rolleyes:
ANDYEFFECT
who mounted gt2 with this project?
it functioned correctly?
thanks
David
#3
Comment withdrawn.
John Lyons
I may be wrong but I think Andre means "corrected" as in adjusted/modded/changed etc.
It says that it's a mod right under.
John
Basic Audio Pedals
www.basicaudio.net/
David
Quote from: John Lyons on October 11, 2007, 09:35:13 AM
John
OK.  I withdraw my comment, then.  Apologies.
ANDYEFFECT
JHS
SA1.1 is a switch:  FX on/ buffered bypass mode.
JHS
ANDYEFFECT
JHS
It's the schem DA posted and acc. to him it shows the GT-2_12. I can't see any FET-switching on the schem, so there's no need for another trannie or output buffer.  IC1a buffers the bypass- and FX-signal.
JHS
ANDYEFFECT
Quote from: JHS on October 15, 2007, 12:39:04 PM
JHS
I will use DPDT, there is no need to use below, 2.2 uf and 100k?
ANDYEFFECT
direct effect... ,there is no need to use below, 2.2 uf and 100k?
JHS
Yes, but maybe there will be a small difference in sound.
I would not drop those 2 parts.  If you want to build it with true bypass switching drop the 1PDT, use a 2PDT and wire it that way.
JHS
ANDYEFFECT
Quote from: JHS on October 16, 2007, 08:42:52 AM
JHS
But I will do more this switching without any direct effect on,
so I was thinking and not use shares below.
