4k99 resistor on wolly mammoth schem???
Started by ambulancevoice, October 15, 2007, 04:43:11 AM
ambulancevoice
ive got a schematic of the wolly mammoth, and i noticed that on the tone control, it says that there is a 4k99 resistor
do these exsist??
i couldnt find a 4k9 resistor either
anyone else who has a w.m. schem could you pm me the actuall resistor value
its the resistor that goes from pin 3 on the tone pot
soulsonic
I believe you could use a 5K or 4K7 there and it shouldn't make any noticeable difference in the sound.
zachary vex
You don't want to go substituting some crap component with a half-assed value in a Woolly Mammoth.  It might trample your entire village.
ambulancevoice
so your saying that it is a 4k99 resistor?
the_random_hero
Completed Projects - Modded DS1, The Stiffy, Toaster Ruby, Octobooster Mk. II, Pedal Power Supply
ambulancevoice
ill just go with a 4k7
thank thou my droogies
soulsonic
People have built it using a 4K7 and it turned out just fine.
nelson
If you want to be as accurate as possible why not just put resistors in series to match the value?
My project site
Winner of Mar 2009 FX-X
rocket
4.99 is an E96 value and DOES exist.
E-Series: http://en.wikipedia.org/wiki/Preferred_number
Still it is is quite likly that it was chosen for other reasons than strictly technical ones, so I also think that you can use 4.7 instead
CGDARK
Quote from: rocket on October 15, 2007, 06:03:04 AM
It is a common value for a metal film resistor type, but not everybody stock it. Check this:
http://www.mouser.com/search/ProductDetail.aspx?R=271-4.99K-RCvirtualkey21980000virtualkey271-4.99K-RC
"Search"...the magic word.
CG ;D
JHS
IMHO the value was taken by measurement, 2 x 10k wired parallel should be a good subtitute.
JHS
