True Bypass for Old Phase 90 - need a diagram, or directions
Started by krhnyc, November 14, 2007, 03:39:22 PM
krhnyc
I have a '70's Phase 90 that I would like to wire true bypass into. It doesn't kill my tone, but I can definitely detect a difference when it is not patched in. That compounded with the fact that the original switch is starting to fail... as long as I am replacing the switch... may as well do the bypass. If someone has a diagram or pic, that would be best.. but I am savvy enough to do it with just directions.
The problem I am having is I cannot determine which wire are the input and output. If i knew that, the rest is cake. can someone point me in the right direction?
Thanks,
KRH
'61 Strat, '56 Tele, other Strats and Teles, 335, tube amps, '68 Vox Wah, '76 Phase 90, '82 CE-2, '83 CE-2, '83 CE-3, Gray Box SCH-1, '89 DC-2, '80's DOD 280 & FX-80, '80's Vesta Fire Chorus, 18V Cool Cat, Home Built Green Ringer & EasyVibe, '92 SD-2, etc
Papa_lazerous
I personally wouldnt go messing with a pedal thats that old and worth a few £'s.  build a clone with TB and keep the 90 safe
krhnyc
Quote from: Papa_lazerous on November 14, 2007, 04:00:31 PM
I already performed the mod on my '68 Vox Wah, with great result (found a diagram on the web). The Phase Mod cannot be any more difficult... I just need to know which wire is which.
krhnyc
Quote from: krhnyc on November 14, 2007, 04:03:22 PM
UPDATE - Mission accomplished. I used the current wiring to determine which wire did what. rewired it for TB with a Carling 316-PP and it works great. Sounds better when turned off and actually better on, the old switch was on it's way out and was having a negative effect on the sound. Feel free to contact me if you need help with this.
