Tremulus Lune Symmetry Mod
Started by Indoor Fireworks, November 15, 2007, 05:04:40 AM
Indoor Fireworks
Hello. I'm having trouble figuring out how I'm going to do this mod. I'm using the Tonepad layout http://www.tonepad.com/getFile.asp?id=84.
The only wiring diagram I could find for the Symmetry Mod was on the Commonsound site http://commonsound.org/tremulus/symmetry.pdf. There, it says you need to wire it to the "fine" pot. The problem is I dont want to have a "fine" control on my pedal. I only want to use one pot to adjust the speed. How would I wire the symmetry mod so I can use one speed pot.
I know its a stupid question, but I'm not too experienced with electronics yet. Also, I'm sure it doesn't help that I'm super tired right now.
Gila_Crisis
it's a simple mod, just don't wire the fine pot and now the wires that from the speed and symmetry pot went to the fine now go both to where it says "Fine 2"
Indoor Fireworks
Thank you for the response, Gila_Crisis. The only problem is that I'm using the Tonepad layout (http://www.tonepad.com/getFile.asp?id=84) which doesn't have a point on the board that says "Fine." All it has is depth, speed, smooth, spacing, and gain.
Can someone translate the symmetry mod from Commonsound (http://commonsound.org/tremulus/symmetry.pdf) so I can wire it into my Tonepad layout?
Gila_Crisis
it's reaaaaaaaaaally a simple mod..... the symmetry pot has to be wired IN PARALLEL with the speed pot!!!
Indoor Fireworks
Oh... Ok. I feel stupid now. Thanks for clearing that up.
