Standalone Marshall Tonestack?
Started by mnordbye, December 05, 2007, 11:59:21 AM
mnordbye
Anyone have a project (schem or layout) for a standalone Marshall tonestack? Going to build a simple EQ, and haven't found the ones i searched for here very interesting.. And i really like how the tonestack in the Guv'nor pedal works.
If no such thing already exists, how should i go about to do this? I guess i could just use the tonestack on it's own, but i think the volume would drop significally then. Any advice?
Magnus N
General tone addict
Deaf Audio at Facebook
MartyMart
Have you looked at the ROG tone mender ?
You can build a standalone, buffer IC up front and a gain make up with the other half after
fairly easy, or "drop one in" to a circuit and add same gain lift at end or the BM final stage, just a few components.
MM
mnordbye
Okay, is see.. Buffer in front and the gain recovery stage after?
I prefer pots to shape the sound, so the tonemender isn't really an alternative.
Magnus N
General tone addict
wampcat1
A down and dirty way of doing it is to make your signal go into a buffer and then into the 3 band tonestack. From there, go into a non-inverting opamp or transistor/foot boost circuit.
Brian
scaesic
i stripboarded a standalone polytone tonestack. its not verified but the schem is next to it for debugging if it doesnt work.
just search polytone on the forum.
arma61
Hi, with a big help of this forum and others I just finished to build this
http://www.diystompboxes.com/smfforum/index.php?topic=63248.0
I'm going to test it this evening, but the prototype is working fine.
the tone circuit is coming from big muff, but I think you can "cut&paste" the Marshall one or, I think, anyone else
Ciao
Armando
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
mnordbye
Thanks, that gave me some ideas.
Magnus N
General tone addict
d95err
Quote from: mnordbye on December 05, 2007, 01:35:46 PM
Eh... take a look again at the Tonemender:
http://www.runoffgroove.com/tonemender.html
(I think you've got it confused with the Runoffgroove Mr EQ project.)
arma61
Glad I could help a bit Magnus N, I normally "take" from here, so I'm happy this time I could "give"
Armando
mnordbye
Quote from: d95err on December 06, 2007, 07:51:57 AM
Thanks! I get confused all the time.  : ;D
I'm usually just "taking" too, so i try to share everything i design.
Magnus N
General tone addict
Paul Marossy
If you have a really high gain circuit and can stand the insertion loss, I have this passive Marshall tone stack that I used on a project once:
http://www.diyguitarist.com/PDF_Files/MarshallToneStack.pdf
Sock Puppet
You might find the Duncans Amp Pages Tone Stack Calculator invaluable:
http://www.duncanamps.com/tsc/
S.
mnordbye
Quote from: Sock Puppet on December 06, 2007, 10:28:04 AM
S.
I got the idea from Duncas calculator.. A great application! Thanks
Magnus N
General tone addict
newfish
So - am I right in thinking the Tonestack could be used after a clean booster to give a sort of Normal Amp / Scooped Marshall sound in on convenient footswitch?
Kind of like a Graphic EQ pedal, but with less pots etc...
...or - after something like a RangeMaster for a bit of gritty fun maybe?
Happiness is a warm etchant bath.
