|AMPAGE| |GEOFEX| |AMZ|
June 18, 2013, 10:35:17 PM
896274 Posts in 97965 Topics by 28963 Members
Latest Member: ricardodvf
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  Pictures  |  Let's see those pedalboards!! 0 Members and 2 Guests are viewing this topic. « previous next »
Pages: 1 ... 18 19 20 21 22 [23] 24 25 26 27 28 ... 32 Go Down Print
Author Topic: Let's see those pedalboards!!  (Read 154342 times)
Ben N
Ben N. - really! Now Israel, once Baltimore
Re: Let's see those pedalboards!!
« Reply #440 on: July 21, 2011, 07:11:28 AM »
 For pedal which requires AC he has no other option, does he?
 T.
A separate p/s would be the option.
Although I don't recall having come across anything with 9VAC requirement--12VAC is more common, AFAIK.
Logged
Thomeeque
Tomas, Prague
WWW
« Reply #441 on: July 21, 2011, 07:44:47 AM »
 How? I don't see any difference between both DC and AC (galvanically isolated!) supply voltages going from the same unit (if done right of course) versus going from two separate units (in relation with amptramp's statement). T.
Logged
Do you have a technical question? Please don't send private messages, use the FORUM!
Ben N
« Reply #442 on: July 21, 2011, 08:53:58 AM »
Aye, there's the rub, as Shakespeare would say. All I'm saying is that two separate units involves no great expertise or risk, as opposed to doing a 9vac output on a p/s designed for DC outputs. Not elegant and not very DIY, but it is an alternative.
Logged
wavley
WWW
« Reply #443 on: July 21, 2011, 09:03:44 AM »
 T.
The Boomerang+ Phrase Sampler is 9VAC, not sure what else is.
Logged
darlingtonpair.bandcamp.com
eccohollow.bandcamp.com
SISKO
« Reply #444 on: July 21, 2011, 12:06:03 PM »
Digitech Whammy and XP series
Logged
--Is there any body out there??--
space_ryerson
Tim M.
WWW
« Reply #445 on: July 21, 2011, 04:22:45 PM »
Do you know of any existing DIY projects that do 9VAC as well? I haven't ventured very far into the world of AC power and transformers, so I haven't figured out how to add a 9VAC out to one of the existing DIY power supply projects that I know of.
 You just need to add another transformer inside or you can use multi-winding transformer for your PSU with one winding dedicated to this output.
 You should start by creating list of voltages (and currents) you need (now and in the "known" future) for your pedalboard and then design PSU according to this list (and pedal topology - you may or may not need isolated voltages for some /groups of/ pedals). Don't hesitate to start new topic in "Building your own stompbox" section for further discussion.
I would beware of sending AC directly to a supply or pedal that rectifies it.
 T.
My pedalboard is pretty simple these days. Everything is 9VDC, except my Digitech Whammy II. That's why I'm asking about 9VAC. I've use two different PSU's as a result. It's not that big of a deal to plug in two PSU's; but it would be nice to have only one! I'll get working on this, and take a re-read of RG's power supply articles.
Logged
Ron R.
« Reply #446 on: July 21, 2011, 06:22:06 PM »
If you are forced by circumstances to supply AC from one box to another where it is rectified, you should use shielded twisted pair or two separate coax cables with grounded shields for the power line to avoid radiated emissions.  The wire separation forms a loop which has inductance and acts as an antenna.  Twisting minimizes the loop area and each twist radiates the opposite polarity of the adjacent one so that radiated magnetic field averages to nearly zero in the far field.  Shielding means that the electric field is not seen outside of the cable.  You may find that you have no trouble, but you may interfere with other equipment such as wireless microphones (although these are normally UHF) or nearby electrical equipment, or your noise floor comes up a bit.
If the AC is not rectified (e.g. used only for tube heaters) then there is not as much of a problem since with a linear load, no new frequencies are created.
Logged
Thomeeque
Tomas, Prague
WWW
« Reply #447 on: July 22, 2011, 02:57:01 AM »
 No rub, "if done right of course" was meant more like if nothing really stupid is done.
 OK, example of the PSU with 9VDC output:
 Same PSU with added 9VAC output, alt. 1:
 Same PSU with added 9VAC output, alt. 2:
 Big deal..
 T.
« Last Edit: July 22, 2011, 03:41:56 AM by Thomeeque » Logged
Thomeeque
Tomas, Prague
WWW
« Reply #448 on: July 22, 2011, 03:16:22 AM »
 Digitech Whammy II PSU output specs are 9VAC 780mA. Easiest way is to simply add transformer with same specs inside the PSU box and just share MAINS (see alt. 1 above).
 Good! As I said, don't hasitate to start new thread about it if you need any help.
 Good luck, T.
« Last Edit: July 22, 2011, 03:18:19 AM by Thomeeque » Logged
Ben N
« Reply #449 on: July 22, 2011, 04:21:19 AM »
Alt 1 is the same thing as two separate PSUs; alt 2 requires a transformer with the correct secondaries. Not a huge big deal, just a requirement.
Logged
egasimus
Adam
WWW
« Reply #450 on: July 22, 2011, 06:01:58 AM »
IMO the greatest danger about having 9VAC and 9VDC in the same unit is the human factor. Having them in separate housings would take up some more space, sure, but it would help at least a little against someone plugging your entire daisy chain of coveted vintage stompboxes into the AC line... Another solution is to just use a different type of plug. Which can be problematic if it means modifying off-the-shelf effects which you might decide to sell at some point.
Logged
Thomeeque
Tomas, Prague
WWW
« Reply #451 on: July 22, 2011, 06:42:33 AM »
 ..but in one box sharing mains and fuse - so is it one PSU or two PSUs? Wink
 Exactly.
 As a builder of the PSU and supply cables (if you would DIY supply unit you would probably DIY supply cables as well) you have some options, e.g. by having different plugs for AC and for DC on the PSU, by bold color codding of the cables, etc.
 T.
Logged
space_ryerson
Tim M.
WWW
« Reply #452 on: July 22, 2011, 06:44:02 PM »
 Good luck, T.
Thanks for the example! If I need help, I'll start a thread.
Logged
TimWaldvogel
Tim W.
« Reply #453 on: July 25, 2011, 10:58:14 PM »
just set up my new board the other day:
the signal goes:
SHO > fuzzfactory > stripped down bigmuff Pi > hotcake > modded super overdrive > custom wah w/ input/output buffers > tuner > analog delay (DM2 clone w/ modulation)> modded mxr phase 90 > modded boss TR2 > amp
That's pretty sweet and simple !! What mods I'd you do to your sd-1? Why about your tr-2? I have both these pedals stock. I would mind getting imvolved in my pedals.
Logged
YOU KNOW WHAT THEY SAY ABOUT LARGE PEDALBOARDS....
.... I BET YOU WISH YOUR PEDALBOARD WAS AS LARGE AS MINE
nexekho
« Reply #454 on: July 30, 2011, 11:58:26 AM »
I like to keep it simple... Guitar->Pocket POD->Behringer Pitch Shifter/Chorus->Crybaby Wah.
No board at the moment.
Also, I need to ditch these mono 2m cables for some shorter stereo patches.  Cry Baby is stereo right?  First two pedals are.
EDIT: Used a smaller image.
« Last Edit: July 30, 2011, 12:02:59 PM by nexekho » Logged
I made the transistor angry.
guitarman89
« Reply #455 on: July 30, 2011, 12:32:13 PM »
no cry baby is mono... Wink
Logged
built: MXR Dist+,dod250-280,dr boogey,IC buffers,cmos drive,multiface,20W SS pwr amps,phase90,tubescreamer,rat,amzMB,wuly mammoth,dod280,zombie chorus
under constur:60W 3886 amp,jcm800 em
www.myspace.com/guitarmanbll
www.myspace.com/filospinatopunk
nexekho
« Reply #456 on: July 30, 2011, 12:38:14 PM »
Is it?  Damnit.  If I was ever going to gig I'd make a switching pedal, but just cutting it out of the chain altogether will suffice.
Logged
the3secondrule
Jeremy N
« Reply #457 on: July 30, 2011, 06:25:36 PM »
the signal goes:
Hey, just saw this Wink
the SD1 - i modded this so much, and so often that I can even remember what was done to it now - it ended up been used on bass
the TR has the internal trimmer for volume (i like my trem with a slight vol boost) and a rate indicator LED.
both pretty simple
Cheers,
J
Logged
"Rock music is mostly about moving big black boxes from one side of town to the other in the back of your car."
Thomeeque
Tomas, Prague
WWW
« Reply #458 on: August 11, 2011, 09:25:42 AM »
This isn't my pedalboard, but I figured I should share anyway. This is Eric Johnson's pedal board from his show I saw last night in Santa Ana, CA. Incredible concert! Enjoy  Grin
 http://www.guitarworld.com/close-gear-tour-eric-johnson-minneapolis
 Proven Smiley T.
Logged
Pigyboy
Christopher J
WWW
« Reply #459 on: August 12, 2011, 04:52:57 AM »
Pedal Board from Gary Schmalzl of Jingo De Lunch with a Wee Beaver guarded by Triple H & The Undertaker!
While I am at it here is a shot of Tim Schippers board with a Little Angel tucked away in there.
« Last Edit: August 12, 2011, 04:58:14 AM by Pigyboy » Logged
And you'll have to admit, I'll be rich as sh*t
I'll just sit and grin, the money will roll right in....
                                                            - FANG
Pages: 1 ... 18 19 20 21 22 [23] 24 25 26 27 28 ... 32 Go Up Print
« previous next »
Jump to:
