Author
Topic: Let's see those pedalboards!! (Read 150658 times)
bean
Brian
Bad.Ass.Alteredsounds.
Logged
MikeH
Mike H - Ann Arbor, MI
Is that a SeekTrem/SeekWah in one?
Logged
iaresee
Gah! When you cobble you end up with three original Coloursound pedals on your board! I'd love to see what your thoughtful board looks like!  here's the board i cobble together for jam night's, pretty much this layout with differing colorsounds, i'll post my gigging board soon.
Logged
cloudscapes
almost. its just a trem, but with 16 steps instead of 8. plus a bunch of other controls, like smoothing
Logged
kurtlives
Chris M.
almost. its just a trem, but with 16 steps instead of 8. plus a bunch of other controls, like smoothing Do you have a project file for it? I always thought it was just so cool.
Logged
vondran
Here's mine.
Logged
AM
Here is mine. I keep it simple. Pedalboard is made out of a metal CD holder. I cut the metal to size and attached black plastic at both ends. The case is (was) a toolbox. I altered the hinges so I can remove the top of the case before playing. The metal board is raised from the bottom of the box with two metal strips running alongside. I also glued a small woodblock underneath the metal board and directly to the case so the board doesn't move back and forth while stepping on the pedals. It can still be taken out if something needs repair though. The black material at the bottom is some really tough but flexible PVC.
« Last Edit: November 15, 2008, 04:08:01 AM by AM »
Logged
sasuke_kun12
Hello
Gah! When you cobble you end up with three original Coloursound pedals on your board! I'd love to see what your thoughtful board looks like!  here's the board i cobble together for jam night's, pretty much this layout with differing colorsounds, i'll post my gigging board soon.  OMFG! An original parapedal! How much that that cost you?
Logged
I declare BANKCRUPTCY!
Leston Braun
Leevi - Finland
Here's my pedalboard in progress. Wiring and powering will be done with George L:s and 1-Spot, pedals will be attached to board with Dual-Lock. Empty boxes are waiting for guts, I have Phase 90, OCD, Hot Cake and Trem Lune coming. Empty space below outlets is for a self-built Wah and volume/tuner.
Logged
gutsofgold
Big Muff, Overdriver, Big Cheese, and Prunes and Custard builds.  Sonic, thats an awesome setup. What's the blue build in the front there? And are those knobs on the big muff in the back stock? They look like the smaller Davies knobs only a little bigger...
Logged
any
a.k.a. whythisreason? Niels H.
I'd invest in some nice patchcables... I had a similar set-up (15ish pedals, mostly delays and pitch related) and changing to George L's made it sound a lot better! Some nice pedals there for sure..  Cheers, Any
Logged
no, it's supposed to sound that way... FOR SALE: Custom TaniWha Fuzz Face PCB's, more here: TaniWha Fuzz Face PCB
elshiftos
Steve!
I had a few homebrew pedals kicking around and came up with this as a means of keeping them together and free from batteries. The psu is under the raised part. The chorus/delay are separately wired to two of the jacks for connection to the amp's fx insert loop, but when the fx loop jacks aren't in use, they appear as part of the normal fx chain - clever eh?  Just need to add some sheet velcro.....one day!
« Last Edit: November 16, 2008, 11:51:27 AM by elshiftos »
Logged
HeimBrent
Espen H.Bjørgan
can I play too? Here's my pedalboard:  And here's where the cables go:  Nils That floorboard looks homemade... You made the switcingsystem yourself?
Logged
Ben N
Ben N. - really! Now Israel, once Baltimore
Here's my pedalboard in progress. Wiring and powering will be done with George L:s and 1-Spot, pedals will be attached to board with Dual-Lock. Empty boxes are waiting for guts, I have Phase 90, OCD, Hot Cake and Trem Lune coming. Empty space below outlets is for a self-built Wah and volume/tuner.  Nice looking work. Hoewever, I would recommend moving things around to keep your wah as far as possible from AC and transformers. Wahs are hum magnets, and a power strip and wall wart a few inches away will likely translate to a lot of it.
Logged
Paul Marossy
Just Another Guitarhead
This is my mini-pedalboard, for when I want to travel very light.
« Last Edit: November 17, 2008, 01:12:48 PM by Paul Marossy »
Logged
fuzzo
Big Muff, Overdriver, Big Cheese, and Prunes and Custard builds.  where have you find the orange box (next to the hot cake) ?
Logged
Dylfish
Dylan B - Perth, Australia
Logged
eleanor296
Andy K
can I play too? Here's my pedalboard:  And here's where the cables go:  Nils hey Nils, What kind of connector are you using? I'm trying to find something that's one connector but can run signals to and from the pedalboard as well as 7-pin midi, so I can interface everything with my rack easier... now if it could carry power too that would be heaven hehe. So yeah, shoot me a pm if you can! Thanks! Andy
Logged
