Author Topic: rangemaster wiring  (Read 4233 times)
plen
rangemaster wiring
« on: January 07, 2008, 08:26:11 AM »
i am building a effect like the original dallas rangemaster.i am using a dpdt switch.can someone tell me where all the wires go to.on the original you have 2 ground wires,collector wire,input capacitor,a capacitor from the pot to the switch,power wire and a wire from the switch to the output switch.i have looked at different schematics and cant see where these go to.i am using a tag board.also is it the same if i wanted build another one using a toggle switch instead of a foot switch.
thanks peter
plen
Re: rangemaster wiring
« Reply #2 on: January 12, 2008, 09:18:14 PM »
fisthegoon,thanks for your help.i cant see where the collector wire from the board goes or where the base capacitor goes.there is also a boost pot to wire up.
thanks peter
FisTheGoon
« Reply #3 on: January 14, 2008, 10:28:05 AM »
Sorry Peter.May i known which schematic you use?  :icon_smile:
plen
« Reply #4 on: January 14, 2008, 10:34:13 PM »
i built it from the geo fex schematic.i have now copied the wiring from a diy pedal picture which was also built with a tag board.but the boost pot does not do anything. i also want to put a dc socket in it.
thanks peter
plen
« Reply #5 on: January 15, 2008, 07:51:15 AM »
i forgot to say that the dpdt switch is only working in one position.when it is switched there is no sound,
thanks peter.
frankclarke
« Reply #6 on: January 15, 2008, 10:41:05 AM »
Search for Rangemaster in the gallery.
