Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
Valoosj
Quote from: pickdropper on January 05, 2013, 11:33:45 AM
Could you possibly share how much such a pcb costs to have made? I'm getting fed up with etching them myself and wouldn't mind just ordering them.
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
pickdropper
Quote from: Valoosj on February 08, 2013, 04:18:01 PM
If you are just looking for a board or two and they are small, the cheapest and best quality option is OSHPark, which will give you three copies of your board for $5 a square inch.  A board like the one pictured would probably be about $12 for 3 copies.
If you want small to medium runs (10-50 pcs or so)., there are places like iTeadStudio and Seed Studio that are popular and have VERY good pricing.  You'll pay less per board, but it takes a while to get the boards and shipping cost can factor in.
If you want to do larger runs, then your options really open up.
guitarmageddon
^ Pickdropper should change his handle to "Jawdropper"
The "Codroach", an Astrotone/Sam Ash Fuzz.
nicofx
@guitarmageddon  - that roach is very nice  :)
Here's my latest minis:
Timmy clone:
Clone of the Maxon NG9:
noobamp
#1224
this approach is amazing.....got me thinking about moving in that direction....
nothing like the smell of hot Bovie in the morning....
fuzzymuff
just built Jack Orman Klon like buffer and using a madbean roadrage to power it up to "18 volts".  Lots of headroom and dynamics at this voltage.
pickdropper
Another Screwdriver, but with a different PCB layout this time.  For this one, everything other than the Germanium is SMT.  Since there is no BC109C in SMT, I changed it to a 5088.  It's a bit more aggressive and has more low end than my other Sonic Screwdriver, but it also uses a different Ge trans than the other one.
HOTTUBES
Pickdropper ...... you make sick pedals !!
TaylorSampson
Here's my very first pedal! I made a Super Hard On clone and decided to try and squeeze it all into a 1590a. It ended up coming out really nicely, I'm very happy with it http://sphotos-b.xx.fbcdn.net/hphotos-snc6/226401_10152666913780232_451395390_n.jpg
arma61
Hi there
this is my latest build, Little Angel by Frequencycentral, with LightEmittingBorder that, with a LED connected to IC2 pin1, flash it in time with the rate, and added a 3n3 cap from pin5 to gnd to get rid of some hiss. Hard to squeeze!!  Sorry for bad pictures... that's all I can get from my phone. Ciao
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
pickdropper
Quote from: TaylorSampson on March 12, 2013, 02:40:15 AM
Great first build!  Don't hide it away.  Show it off inline:   :icon_biggrin:
@Armando...don't think were letting you get away without showing the led border on... :icon_cool:
TG Flatline
Quote from: deadastronaut on March 13, 2013, 04:32:46 AM
Absolutely!!
arma61
 ;D oh I thought you could imagine it.. a blue LED flashing in time with the rate speed  ;D  ;D !! " But to keep you vultures happy" I  I'll see what I can do... it's in the shop now  :icon_mrgreen:
Stay tuned!
Ciao
rousejeremy
Quote from: flo on October 14, 2008, 04:28:19 PM
Regular true bypass FX looper. Perhaps nothing special but its my first 1590A usage.
As an extra, I have added measurements (in mm) on where I drilled the 1590A enclosure.
This is helpful. Thanks for the drilling measurements.
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
stahoo8
Hi All. My copy - isp decimator
and other copy:
ep booster and maxon od808
suhr riot
TS808
wampler plexi drive
OCD
Rebote delay 2,5
Big Muff "green"
EA tremolo
Spring reverb ( accutronics BTDR-2 module+ application)
opto compulator
flipster - bass preamp
fuzz factory
2 ch footschwitch
I greet
rocklander
look lovely, but need moar gutshots..
stahoo8
Thanks. All pcb are designed by me. Example:
rebote delay 2,5
