Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
tubelectron
Quote from: solderman on June 13, 2010, 03:42:43 AM
You can use small litium batteries @3V like this ones and pack them together to get 3x3=9V.
Yes, solderman : it is a good idea "to save room" in the 1590A that I already thought about, but not tested it... Why ? I think that this kind of battery is just able to power one 2N3904 and nothing more, with a questionable battery life expectancy and moreover at a much higher cost than the standard 9V battery. But I may be wrong : have you got some experience about powering stompboxes with such batteries ?
A+ !
I apologize for my approximative english writing and understanding !
http://guilhemamplification.jimdofree.com/
solderman
As I posted earler
I used it with a Fuzz Face. I have not used it much so I cant really say something about the battery life time but it works.
A  CR 2016  (Ø20,0x1,6) is 3V and  mAh
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
tubelectron
Thanks solderman.
Anyway, the "CR 2016 x 3" idea is to be considered and to be tested, simply because it saves a lot of place compared to a 9VDC Std batt. If it worked with a FF, then probably a lo-pwr.  single 2N5457 booster should gave good results in terms of batt. life duration : I will dig it. Wait and See...
A+!
There are standard 12 volt tubular batteries that are very small.  I have one in the car alarm keyfob.  Mine is an Energizer A23 which is 1.14 inches long by 0.4 inches diameter and may be able to power a small effect like a single FET amplifier.
tubelectron
Thanks amptramp for the suggestion.
I found that the cost in France for an Energizer A23 is around 5 euro ( 6-7 USD), around the half for a battery holder, and this seems not to be an esoteric model. So it's a very good alternative to the classic 9VDC. I'll look further.
A+!
Quote from: tubelectron on June 18, 2010, 12:53:16 PM
A+!
I get them locally at Sayal (in the Toronto area) for $2.  If your current drain is very light, they should be OK.
Br4d13y
i used one of those to power a ruby in a small enclosure. they work great
freedom is the freedom to say 2+2=4
tubelectron
Well, the A23 batteries are cheaper in Toronto than in Paris : let's face this awful drama...
Thank you guys for your advices and suggestions on battery compactness.
A+!
solderman
Hi
Finally found time to build the MXR phase 90. I discovered and corrected a trace error at IC3 so now the layout is corrected and verified. I'm not going to box this build since I did not have any 2N5457 in stock and used 4 not that well matched 2N5485. It does not sound as good and swoooshy as my Tonepad build with matched 2N5457 and I had to jumper around the trace error. But this is what it look like "inside".
And here is the parts layout and PCB transfer
http://solderman.fatabur.se/MXR90/P90 PCB.pdf
http://solderman.fatabur.se/MXR90/P90.pdf
www.soldersound.com
darron
dune2k
Quote from: darron on June 23, 2010, 05:28:29 AM
Quote from: solderman on June 20, 2010, 05:18:05 PM
awesome job!
always wondered, where do you get those cool MKT caps? :D
Are those that rare in the US? They're MKS btw, MKTs look a little different.
I'm living in Germany and they're the cheapest ones you can get here (about 0.12 - 0.50 Euro a pice) aside from those super cheap crappy caps...
solderman
Thank's
As dune2k wrote They are all over the place her in Europe and you can probably get them down under as well.
check out  this, 2 EU and one US
http://www.banzaieffects.com/
http://www.musikding.de/index.php/language/en/XTCsid/fd7a910ad20ed03921316721eeeb0e47
http://www.smallbearelec.com/home.html
www.soldersound.com
tubelectron
Quote from: tubelectron on June 19, 2010, 07:26:51 PM
A+!
Today I found a pack of 2 A23 Energizer batteries for 6,25 Euros at the local supermarket : compact, cheap and even not rare. That' what I will use to power my release to come in a 1590A box.
Thanks again for your infos,
A+!
darron
ah i see. thanks solderman. i don't think smallbear has them as i've never been able to see them... i guess i'll need to bight the bullet and get some from banzai or something (:
can i get these boxes in the uk?.........i havent seen them anywhere....?????
i want to make a little(obviously lol)..2 watt amp head..
edit..found em...lol...pricey though...
£5:17 for the box...£12.00 to deliver..from mouser uk....wtf?..arghhhhhhhhhhhhhh...
i'm not paying that..... :icon_rolleyes:   .
1878
They've got them in my local Maplin. About 3 quid.
Quote from: 1878 on June 24, 2010, 01:49:50 PM
oh right, im off there tommorow...need a bigger bread board....i'll have a look...cheers.
blooze_man
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
solderman
Hi I posted this in the Pictures thread but  this might be a more suitable place. ;D
This is the supreme compressor "Diana Ross".
It's a layout that will build both the MXR Dyna Comp and the Ross Compressor. All fitted in a small box. Of cause it will fit in whatever bigger box as well. The layout is based on the schematic found on Tonepad but what I understand it is stock. I made some mods suggested by Mark Hammer (see fuzzcentral.com)   The tin can is a NOS mojo CA3080 OTA made in India, that I by mistake ordered from Small bear in stead of a DIL8 but I think it looks cool.
And here are the project files
http://solderman.fatabur.se/Diana Ross/Diana Ross PCB.pdf
http://solderman.fatabur.se/Diana Ross/Diana Ross Project File.pdf
www.soldersound.com
