Swirl finishes, "Dragonfly style !" (56k warning for pictures !)
Started by Dragonfly, February 01, 2008, 12:40:48 AM
suprleed
"That's the way I play" ~EC
Dragonfly
Quote from: greigoroth on February 01, 2008, 11:26:37 AM
That's your best yet Andy, looks like jade!
I hadn't even thought of that, but yeah, you're absolutely right...it DOES look like Jade !   :D
Dragonfly
Quote from: suprleed on February 01, 2008, 12:25:08 PM
Sweet!  All I can say is sweet!
Thx
I hope you get a chance to give the technique a try...its a LOT of fun !
mdh
Huh, so I take it that it's more or less self-leveling due to the thinning?  I would think that the toothpick swirling would leave little scratches behind in the surface of the paint.  Did you have to mess around a lot to get the right degree of thinning?
Dragonfly
Quote from: mdh on February 01, 2008, 02:25:19 PM
drying it out under the light evaporates the water and levels it out quite nicely...not perfect, but very good.
a light wet sanding after every 2-3 coats of clear gives a nice finish.
paint consistency is really the key, imo ...thats why i mentioned a "more or less" ratio in regards to paint / water...the artist cups work great...1/2 full with paint, add water till 3/4 full...then mix.
sixstringphil
I'm buing shares of stock in acrylic paint manufacturers! I can see a sudden spike in sales this weekend at Hobby Lobby's all over the country!
Do you have any pics of the enclosure you labeled? Did you use decals or hand paint them?
Dragonfly
Quote from: sixstringphil on February 01, 2008, 05:44:44 PM
decals
moro
Hey Dragonfly, did you do this enclosure differently? With all the others, the paint has dripped and smeared down the sides, but on this one, there's a very distinct swirl on the sides as well. No smearing.
jimbob
Thanks for the tutorial- I'm going to give it a try in the next few days if I find the time.
also
QuoteR.G. states-   I was simultaneously experimenting with how thick/durable I could make a paint coat without going to epoxies
What kind of epoxies? How does that work? Can you buy a can of epoxy paint?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
nordine
Quote from: moro on February 01, 2008, 08:49:52 PM
seems like he added less water than in the others
Dragonfly
I swirled the sides as good as I could on that one. Usually I just let it drip...I kinda like that look...but on the one you pictured I did the toothpick treatment to the sides while it was drying. :)
Dragonfly
Quote from: nordine on February 01, 2008, 09:37:07 PM
It may have been a bit thicker..I KNOW the magenta was thicker.
This is all a learning process for me...but I'm getting it down, at least a good working method for "me"...
Heres one I did today...
moro
The bubbly detail around the holes in that last one is delicious.
I am so trying this this weekend. :icon_biggrin:
Dragonfly
Quote from: moro on February 01, 2008, 09:49:50 PM
DEFINITELY let me know how it works for you. Post pictures too ! :)
Marcos - Munky
I tried this today. And guess what, in a Dragonfly's effect (a Golden Dragon OD) :icon_mrgreen: :icon_razz:. I will try to take some pictures of it and post here, but my work is nowhere near Dragonfly's :icon_redface:. But I think it went good as a first try.
Dragonfly
Quote from: Marcos - Munky on February 02, 2008, 12:48:56 AM
I definitely want to see pics ! I'm looking forward to it....
This method takes a few tries to get a "feel" for it, but the results are awesome once you figure everything out !  ;)
andrew_k
Thanks very much for posting this, I've got just the pedal to try it out on -- a hammond BB with a SHO going into the 12AU7 tube boost that dano posted. I'm lovin' the breakup caused by cranking the boost; much nicer than the gain pot :icon_twisted:
Anyway, the point of this post is to ask if you (or anyone else) has attempted this on a powder-coated enclosure? It'll be a couple of weeks before I can drill mine and get to painting, but if no one's done it by then I' guess I'll be the guinea pig...
Marcos - Munky
Well, here's my pictures. First of all, it's my first attempt at Dragonfly's method, and also my first attemp at painting an enclosure.
Fist the unpainted box. I used a cheap aluminuim box sold at the local stores.
Now the painted box, after about 6 hours drying outside my house, and before any clear coat layer.
My errors:
- too much water
- trying to create the swirl effect, I mixed the colors too much with the toothpick, and they mixed together
Like Andrew said:
QuoteThis method takes a few tries to get a "feel" for it, but the results are awesome once you figure everything out !
Dragonfly
Once you clear coat them it might look really cool...I kinda dig the top especially !  :)
Boogdish
