|AMPAGE| |GEOFEX| |AMZ|
May 19, 2013, 06:03:10 PM
890784 Posts in 97549 Topics by 28668 Members
Latest Member: nenecarrizo83
Home Help Login Register
DIYstompboxes.com  |  Projects  |  IC-based Overdrive  |  1st time try @ Breadboarding 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] Go Down Print
Author Topic: 1st time try @ Breadboarding  (Read 3761 times)
J.D.
joe d
« on: February 24, 2008, 04:51:02 PM »
    This is my 1st breadboard attempt ever and it sounds pretty good to me. I used a TL071 for the IC, works fine and I really feel like I learned a little bit about
how this stuff is done (probably just enough to be completely wrong at most of it).
    I would like to try to commit this to a PCB and box it up(maybe use the diode compression project instead of an IC). I just attempted my 1st PCB layout using the DIY Layout Creator but I'm not at all confident it's right. I'm sure I wasted some board space but that's about all I'm sure of.
    What's the easiest way to do a layout---starting with the ground trace and working in or in this case starting with the IC and working out? Or is it better to start with the power section? I don't have a clue. Maybe all these question belong in a different thread but this is the beginners section so I thought I would try here.
Logged
J.D.
joe d
Re: 1st time try @ Breadboarding
« Reply #1 on: February 24, 2008, 05:19:08 PM »
 Had trouble inserting image
Logged
gaussmarkov
paul
WWW
« Reply #2 on: February 24, 2008, 05:23:33 PM »
hi J.D.,  welcome to the forum! icon_cool
there are probably as many ways to approach this as there are people.  so take my suggestions as just a few among lots of other good ones.  perhaps others will chime in with their favourites.
to start, i like to spread out the parts more or less like the schematic.  i think i picked this up from aron's beginner project.
then i concentrate on putting in the traces for the signal path first.  i don't worry much about ground or power supply stuff until after the signal path is done.  try rotating the IC around to see what works best.  i also pay attention to pots at this stage, because i want the layout to fit where the pots are going to go, usually along the top edge.
then i keep start the +9V and the GND traces side-by-side at the bottom.  i run the ground trace more or less all the way around the outside and the +9v inside of that.  in this circuit, VA takes the place of +9V.   i treat the virtual ground (VB in this case) traces like the +9V traces.  if i seem to need jumpers, then i would restrict them to these three (GND, VA, VB) because they are supposed to be relatively "quiet" traces---their voltage is approximately fixed.
you could also try looking at what others have done after you have wrestled with the problem a little.  i have a layout for this circuit here.  tonepad.com has a layout.  i'm pretty sure that generalguitargadgets.com does.  i'll bet markm's gallery has a layout because he laid out almost everything before he retired from stompbox circuits.
hope this helps, paul icon_biggrin
Logged
gaussmarkov.net:  layouts & eagle
gaussmarkov
paul
WWW
« Reply #3 on: February 24, 2008, 05:24:43 PM »
ah, we are piling up posts on top of each other. icon_wink
it looks like you have already made great progress!
Logged
J.D.
joe d
« Reply #4 on: February 24, 2008, 06:53:55 PM »
 Hey Paul, thanks for the advice. I checked out all 3 of the layouts you mentioned and I'm not surprised they all look much cleaner and less cluttered than mine.
 I'm going to study em and clean mine up a little. Maybe try to incorporate that diode compression into it. Just wanted to learn how to do it because I figure it will help me more than just taking a PCB off the net and soldering components wherever it say to solder components.
javascript:void(0);
Smiley
Logged
gaussmarkov
paul
WWW
« Reply #5 on: February 24, 2008, 08:06:00 PM »
Smiley
i think you are right.  i certainly learn much more that way.
i hope you didn't get the impression that i was suggesting those other layouts as substitutes for yours.  i hope you do your layouts first before you make comparisons.  and that you will stick with your own.   there's a lot of satisfaction (and learning) in rolling your own.   icon_cool
Logged
J.D.
joe d
« Reply #6 on: February 24, 2008, 08:34:35 PM »
   Not at all,always preferred rolling my own" back in the day".
   Now to learn how to post a smiley face.
Logged
Pages: [1] Go Up Print
« previous next »
Jump to:
