Attn: Payback v1.1 Errors
Started by The Tone God, February 26, 2008, 03:39:33 PM
The Tone God
Hello everyone,
I just realized that the schematic published on my site for Payback v1.1 has some major errors. The errors involve the pin numbers of the 4093 IC. The part library I used in creating the schematic has a mislabelled set of pins on the 4093 so the pins on the schematic do not match what the actually part pin numbers are. It is my fault that I did not check the pinouts myself before publishing. I apologize for the trouble this has cause.
To correct the errors reverse pins 8 and 10 and pins 4 and 6.
I'll publish a corrected schematic later.
Andrew
Valoosj
Don't forget about who found out ;-)
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
Auke Haarsma
Quote from: The Tone God on February 26, 2008, 03:39:33 PM
I just realized...
Quote from: Valoosj on February 26, 2008, 03:40:29 PM
exactly! Valoosj and Aad put a lot of effort in figuring out this error on the schematic. I also encountered most likely this error a couple of months back when I breadboarded the payback (not recognizing the error though).
Yorick gozer, je doorzettingsvermogen wordt beloond!
