What tone control for Bazz Fuss?
Started by kismet78, March 10, 2008, 12:39:31 PM
kismet78
I was messing around with the Bazz Fuss circuit over the weekend, but got stumped on tone shaping. I tried using a BMP tone control, but it really seemed to take a lot away from the Bazz Fuss' character. Maybe make the BMP tone control switchable so I can take it out of the circuit when I want?
A high-pass filter at the input cap or just switchable input caps seemed better at retaining the Bazz Fuss sound, but maybe not flexible enough?
Anyone here find a tone control they liked for it? Anyone else have any ideas they can throw out?
syndromet
The thickness-controll from the Bazzfuss deeluxe is pretty effective
My diy-site: www.syndromet.com
kismet78
Quote from: syndromet on March 10, 2008, 02:14:39 PM
I think that's what I meant by low-pass filter. The only thing I didn't like about it compared to the BMP tone control I tried was that there's no way to dial out any high end.
rackham
I put an SWTC on mine and liked the results.
kismet78
Quote from: rackham on March 10, 2008, 02:22:57 PM
That looks really promising. I'll breadboard it tonight.
superferrite
Tell us how it goes.  I've got most of the parts to put this one together tonight!
I was thinking of putting a BMP tone control after the BF and throwing an LPB1 after it--I have a circuit for one sitting around unused.
Will this sound alright?
Psychedelic Garage Metal
kismet78
Do you recall the values you used?
I only had a few minutes to try it out tonight, so I didn't get a chance to diverge from the recommended jumping off points. At first listen it didn't seem to have nearly enough sweep for me.
kismet78
Dragonfly
Quote from: kismet78 on March 11, 2008, 01:05:07 PM
Quote from: Dragonfly on March 11, 2008, 10:11:54 AM
http://www.runoffgroove.com/whisker.html
Are you suggesting the muff-type tone control or the alternate?
i'm suggesting that the whisker biscuit is very near to what you're trying to accomplish.... bazz fuss / bmp tone control / gain recovery stage...the whisker also adds a boost stage on the front end.
kismet78
Quote from: Dragonfly on March 11, 2008, 01:41:34 PM
You're right, that's very close to what I'm trying to accomplish. Damn it.
rackham
Quote from: kismet78 on March 11, 2008, 05:02:35 AM
I'm pretty sure it was the last one on this page:
http://www.muzique.com/lab/swtc.htm
Definitely pretty versatile for a bass.
kismet78
kismet78
#13
OK, I'm going to run with the Whisker Biscuit, but I'm also after a bit more versatility (i.e. standalone boost, whisker, bazz fuss solo, with or without tone control). I'm playing around with a tighter perf layout (1590B!). Yikes.
First off, I'd like to be able to bypass the tone control via spdt mini-toggle. I'm thinking I should be able to wire the switch right before R8 and before C5. Correct? Am I asking for trouble with the following recovery stage since there won't be the db loss from the tone control? Should I be bypassing the recovery stage too if I don't want to use the tone control?
Next, the part that's stumping me. I also want to make the boost and the bazz fuss sections toggleable separately, but on which side of C2 to insert the switch has me confused. Would I put the boost switch before C2 and the bazz fuss switch right after C2, so that it's available for both as either output cap or input cap respectively?
I want to have some control over the boost for when the bazz fuss is switched out, better to use the collector resistor (as shown) or the emitter to ground?
I have some other ideas, but maybe that's enough for one post...
kismet78
kismet78
