sub for 3.3uF NP cap in AMZ mini-booster?
Started by Wounded Paw, March 20, 2008, 04:05:47 PM
Wounded Paw
I can't find a 3.3uF non-polarized capacitor locally, is it safe to sub in a 1uF non-polarized cap?  What effect will that have.
I have a 3.3uF tan cap that appears to have a - marking on one side, I take it that means it's polarized?
Use the 1uF. The cap is driving an impedance of about 500K. With a 1uf, the rolloff at bass is F = 1/(2*pi*500K*1E-6) = 0.318 Hz. With a 3.3uF cap that goes to 0.096Hz. The lowest note on a guitar in standard tuning is 82Hz.
By the way, putting a 1K resistor between the Q1 source and the Q2 drain and taking the signal off the source of Q1 improves the circuit's performance a lot. See "Modding your Mu-Amp" at GEO.
MikeH
Quote from: R.G. on March 20, 2008, 04:09:48 PM
So you mean put a 1K resistor between the Drain of Q2 and the junction of C2, C3 and the source of Q1?
No. Leave C3 attached to the drain of Q2; call this point 1. Leave C2 attached to the source of Q1; call this point 2. In the schematic as it is now, these two points are attached by a wire. Break that wire. Now point 1 is still the junction of C3 and Q2.  Point 2 is still the junction of C2 and source of Q1. But the two points are not connected. OK so far?
Now put a 1K resistor between point 1 and point 2. C3 is still attached to drain of Q2. C2 is still attached to source of Q1. But now there is a 1K resistor between the source of Q1 and the drain of Q2.
C3 stays with Q2. C2 stays with Q1. In between there's a resistor.
mnordbye
How does that improve the circuit? I'm already "over the top" pleased with my mini-booster. :)
Magnus Nordbye
General tone addict
Deaf Audio at Facebook
It improves the circuit by providing it a low impedance output. It will drive other circuits without treble loss, and with higher gain.
DuoJet
I'm having the same issue! Would a 563k cap also be a suitable substitute? I have one on hand and would like to get this project started.
If a 1uf cap provides for a rolloff around 0.3hz, then a 560nf cap is going to move you up to that dangerous dangerous territory of rolling off around 0.6hz.  :icon_wink:
Bottom line?  Don't sweat it.  Use 560nf.
DuoJet
Quote from: Mark Hammer on September 19, 2011, 11:19:27 AM
OK, maybe I'll risk it. I'll be sure to wear a full body crash suit and the requisite eye protection when I test it.  ;)
WGTP
.1uf is used in many designs with the Mu.  Stick a .22uf greenie in there for max bass and resonable size.    :icon_cool:
Stomping Out Sparks & Flames
kbibs
RG,
I've read your explanation several times and compared it to your "Modding the Mu-Amp" article, (thanks for that by the way), and I keep concluding that you have your cap #'s reversed. C3 should still go to source of Q1 and C2 should go with Drain of Q2, right? ... if not I'm totally confused!
soggybag
I seem to recall a quote from Jack Orman saying the 3.3µf cap was chosen because it was what found on his bench at the time.
Quote from: kbibs on September 20, 2011, 12:49:23 PM
Yeah that's right, or it matches the "mod your mu amp" example anyway.
rosssurf
Viewing this layout,http://www.aronnelson.com/gallery/main.php/v/French+connection/Vero+Layout/AMZMosfetBoost.jpg.html how would I acomplish what you wrote below.? I am not real good at truly understanding the signal chain of a circuit, I am just a paint by numbers kind of guy. Would I simply cut the traces somewhere and add the 1K resistor? Is it even  possible to do this mod with this vero layout ?
Quote from: R.G. on March 20, 2008, 07:04:20 PM
Quote from: rosssurf on September 20, 2011, 06:15:11 PM
Viewing this layout, (AMZMosfetBoost) how would I acomplish what you wrote below.? I am not real good at truly understanding the signal chain of a circuit, I am just a paint by numbers kind of guy. Would I simply cut the traces somewhere and add the 1K resistor? Is it even  possible to do this mod with this vero layout ?
It's not possible. That's the "MOSFET Booster", not the same animal as the "Mini-Booster", which has two stacked FETs. The names are confusingly similar though.
