Need Ibanez Overdrive II Hummingbird Schematic
Started by soapamp, March 30, 2008, 03:48:08 AM
soapamp
I'm looking for Ibanez Overdrive II Hummingbird (od850) narrow body which install MC1458 opamp.
George Giblet
I believe this either it or something very close:
http://home.hawaii.rr.com/stompbox/IBZ-OD2.jpg
You should check it.  The LED + resistor + zener probably aren't in your unit.
(there was another schematic on the web called OD2 but it had quite a few errors.)
One thing I would like to know is whether the diodes are silicon or germanium?
Greg_G
Quote from: George Giblet on March 30, 2008, 05:35:53 AM
If the schematic you posted a link to is right... it says Ge diodes.
soapamp
thank.. for the schematic.   I think it should be correct.  I will check with the original unit of my friend.
George Giblet
Yeah, I know!  The "erroneous" schematic (no link) shows silicons.
If I had to make bet I'd go with the Ge diodes because:
- Patrik probably would have got that right
- The first stage is more or less an MXR distortion plus, which used Ge's
but...you never know...
