The Bear Boost Plus
Started by smallbearelec, April 09, 2008, 12:03:36 AM
smallbearelec
I had multiple motivations for doing this design. http://www.smallbearelec.com/Projects/BearBoostPlus/BearBoostPlus.htm
Part of it was about finding a good vehicle for using low-gain germanium, but I also wanted something that would be a good first pedal to manufacture: a relatively simple boost that would be different and unusual enough to call my own. I think this is it; it can sound like either an FF or an RM depending on settings, but the combination of FET boost and adjustable soft clipping gives it some unique properties. The full kit with board and drilled case will be available this summer.
SD
jonathansuhr
NICE! Definetely on my build list.
jimbob
QuotePC board will be available in mid-to-late Summer '08
Will the board be like the pic or a manufactured  PCB? Id really like a pre-manufactured board as I dislike perf these days. I'll make a few when they come out. Nice work Steve! ( or whoever wrote the email from Smallbear:) )
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
Auke Haarsma
From your article:
Quote from: smallbearelec
R11 in my prototype is a single 100 meg resistor, but it can be 5 x 22 meg in series, or you can use R. G. Keen's Millenium Bypass circuit.
Is that really 100M? The biggest value I have is 10M, or does 'meg' mean something else?
greigoroth
Awesome idea Steve!
I am not good enough to look at the design and say if it is cool or not but based on the description, wow, great idea!
Built: GGG Green Ringer
ambulancevoice
Quote from: Auke Haarsma on April 09, 2008, 03:33:36 AM
From your article:
yes, meg means something else
it means mega ohm
:D
but yeah, its 100M (mega ohm) like he wrote, 5x 22M in series or blah blah
Auke Haarsma
lol
But why use 100M? Wouldn't it better to just leave the connection open (as in 'not connected)? I've not seen such a large value in a stompbox yet.
ambulancevoice
Quote from: Auke Haarsma on April 09, 2008, 08:51:04 AM
lol
r11 (or the 100M) is needed there to bias the transistor
and you dont have to use that LED circuit anyway
there is R.G.'s Millennium Bypass, or Joe D.'s LED trick
there have more regular values
smallbearelec
Quote from: jimbob on April 09, 2008, 01:29:11 AM
It will be a ready-to-solder PCB. The design is very similar to the perfboard version, but the factory "scrunched" and optimized the layout to make it a little smaller. I have built a prototype on a sample, and the production boards are being manufactured now.
