Switching Question
Started by msurdin, May 06, 2008, 03:04:17 PM
msurdin
Hey Everyone.
I have been wondering after seeing a post showing the bottom switch here > http://www.philmore-datak.com/mc/Page%20187.pdf
The big silver momentary one with black round button.
I have been building a big cornish board using all GGG Effects.
Could I design loops that would be controlled by this momentary switch but still have the same switching system In the attached linked diagram?
I guess I could just use a mini 3pdt toggle inside to keep everything on, and put them in a loop which the momentary switch could bring it in and out...
I just can think how the buffers would work... I understand the one after the effects that need it would be fine.
Some effects like the wah have been taken out...
I hope this all is easy to understand...
Matt
aron
I didn't really understand the question, but I think if you are using momentary switches, then you need something like a relay or some other way of switching.
msurdin
I began thinking if I left the effect on like if something is in a true bypass box... then the true bypass box would just be a momentary switching unit..
Is that easier to understand?
I didn't know how to explain it...
msurdin
Are there any switches around that can be screwed down and big like what I showed that are just DPDTs?
