Voetsek sequenced tremolo PCB layouts and instructions
Started by cloudscapes, May 25, 2008, 10:47:07 AM
cloudscapes
hi!
a number of people asked for PCBs and general info on how this was built. so I prepared these :P I hope all the info is there! here is a zip with these same instructions as well as the PCB traces in 600dpi: voetsek_tremolo_diy_instructions.zip
/spam
{DIY blog}
{www.dronecloud.org}
Pushtone
Brilliant. Your build is most impressive and inspiring.
Thanks for the excellent documentation.
I'll let you know if I see anything.
I don't recognize "Vanishing Moon".
Did you mean to write Vanishing Point?
Pushtone
cloudscapes
#3
thanks for linking the video :)
I got the vanishing moon name from here:
http://compiler.kaustic.net/machines/vanishing-moon.html
I found it before the vanishing point (which I never really looked at)
thanks to both of them I guess :)
I'll probably do a revision of these docs later. I just realized I dont really explain what the controls do.
{DIY blog}
Tuemmueh
Great project, thanks for providing all those informations!
cheers ~Timm
cloudscapes
I'll clean up the schematic and release that too once I have a bit of time. the sequencer part is based off of this:
http://www.electronics-project-design.com/DisplayLED.html
{DIY blog}
andrew_k
Wicked, thanks for going to the effort of writing this up.
If I ever come across 20 50k pots for cheap, I know what to do with them  :icon_mrgreen:
cloudscapes
thanks andrew ;)
(and I guess... bump)
speaking of pots, I'm going to start mounting them directly on PCBs, seeing how I now have a drill press and can do much more presice measurements! it will also make assembling something this complex a lot easier and quicker and thus encourage me to perhaps build a couple for people.
{DIY blog}
Tuemmueh
#8
Quote from: cloudscapes on May 25, 2008, 07:45:55 PM
Is this still going to happen as I'm still interested in this project?
Or let me just ask: Where is the reset-button connected to? I don't find it anywhere and in the linked Sequencer-Schem, there is no reset-button either.
Sorry - can't help kibitzing a bit.
The 4514 is a big chip, and was never used in large volumes like some other CMOS was. You can sub in two 4028 or 74C42 14 pin chips at the cost of some rewiring and have it be easier to find chips. Likewise, I think you can use a pair of cd4555's, or even a pair of CD4051's to do the decode thing. The CD4040 counter will do the entire oscillator/counter in one chip if you give up the up/down thing and only use count up.
Nice build.
deathfaces
Did anyone ever have a crack at this? I was thinking of giving it a try. I also don't see the "reset" switch connection in the diagram. Was wondering if cloudscapes had any advice to offer.
AudioMime
AUDIO MIME
Quote from: rousejeremy
Stick the Tremulus Lune in a Feedback Loop and your neighbors will call the cops on you. Which will be awesome.
