Drop dual 15v to dual 12v
Started by StephenGiles, May 26, 2008, 05:55:25 AM
StephenGiles
Can I do this Penfoldly by using 1N4001s for instance to drop the voltages then a hefty electrolytic to smooth it out? My mind's gone blank on this!
jakehop
Yes, that should probably work with 5 diodes each way. You could also use a 7812 and a 7912 if the -/+ 15V source isn't a stable one.
Jake
StephenGiles
Thanks, my board with 25 ICs running would eat up 2 PP3s in 10 minutes!
