boosting the signal after adding passive tone ?
Started by jonjon, June 02, 2008, 08:27:15 AM
jonjon
 hi
i have made a few fuzzes now. and really like adding Jack Ormans stupidly wonderful tone control http://www.muzique.com/lab/swtc.htm.
but find it lowers the signal of the fuzz, so when bypassed the clean is louder the the fuzz.
is there a way to boost the signal so it is a bit louder when the fuzz is on?
i put the tone control circuit after the fuzz.
thanks for any help
jon
john
Check out the this Little Big Muff schematic: http://www.montagar.com/~patj/lbgmuff.gif
You could add the little boost circuit which starts after the tone switch - from the 0.1 cap onwards - it's very similar to the LPB-1: http://www.montagar.com/~patj/ehbsters.gif - you could even add one of them!
GibsonGM
I did that - used the LPB-1.  I run the FF wide open (no volume) and have the volume on the LPB as the 'master'...works pretty well!   Might need 'tweeking' but should work fine!
jonjon
thanks guys lpb 1 it is then.
Quote from: GibsonGM on June 02, 2008, 07:15:01 PM
ill try it out on the  bazz fuss( christian) from homewrecker it has a 100 k pot at the end for the volume, if i use the lpb as the master i guess i just replace that pot with a 100k  resistor
john
jonjon
ok so i did it . works great . i used the section of the little big muff that frequencycentral put a link too, thanks heaps :icon_wink:.
i just worked with what i had at home so i had to use different value resistors and tranny . but worked well.
i put it after the volume of my fuzz and emitted the vol from the boost circuit .
anyway thanks guys for your help. love this site
john
john
GibsonGM
