a rebote delay idea...
Started by dschwartz, June 03, 2008, 04:24:23 PM
dschwartz
Hi all..
i had the idea of using a lfo driven panner to the output of a rebote delay, to make it pseudo-stereo, pseudo ping pong-ish...making the signal go left to right at different speeds and depths (like a speed and "spread" controls)
i thought of an astable multivibrator to drive 2 leds, one for each channel..but to control speed and depth it would need 2 dual pots..and i don´t like that..
a dual pt2399 delay rebote, with the panner at the input of the delay chips would work better, but seems like a lot of work..
maybe a sine-cosine oscillator? any ideas? thoughts?
Tubes are overrated!!
http://www.simplifieramp.com
The French connection
Hi! BYOC did a nice ping pong delay using two pt2399:
http://buildyourownclone.com/pingponginstructions.pdf schematic included...
sound really good BTW...
http://youtube.com/watch?v=oOzocTjGQYE
Dan
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
Effectively you need a voltage controlled panner - two VCA's driven by one LFO, VCA 2 receiving an invertion of the LFO. Only one knob needed for speed, single gang. Another for depth.
Yeah?
dschwartz
yes i´ve seen that..looks great
but i think having a panner would give more original effects, at least i have never heard one..imagine your delay trail traveling from left to right, at a different rate that the repeat time..at high speeds, maybe will sound reverb-ey
dschwartz
Quote from: frequencycentral on June 03, 2008, 04:44:43 PM
Yeah?
you mean.. a single lfo driving two opamps, one non inverting and other inverting?
VC panning is pretty awesome - use it on my modular - especially when the panning is driven by a gate referenced to the beat. You could use something like a trigger sensor driving a flip-flop to pan each seperate note.
Quote from: dschwartz on June 03, 2008, 04:47:21 PM
Yeah?
Single LFO yes. Drive VCA 1 directly, VCA 2 via a single opamp inverter.
LFO > VCA 1
LFO > opamp inverter > VCA 2
the LM13700 dual transconductance opamp would do the dual VCA job - check the spec sheet.
dschwartz
Quote from: frequencycentral on June 03, 2008, 04:48:32 PM
hmmm..konichiwa?  didn´t get that last thing, but sounds like something that gets your rythm and pans at that rate?? hmm sounds great, but a little too sofisticated (at least for me)..
maybe a standalone LFO panner (tremolo if one side is used) is a better idea..
puretube
Panner at the outputs wouldn`t repeat clicks (ticks)...  :icon_wink:
Quoteauthor=puretube link=topic=68405.msg546844#msg546844 date=1212527252]
Could you drive the panner from the PT2399 rate LFO via a 4013 flip-flop though? That would do it.
puretube
Just divide the clock... independant of pre- or post-panning... :icon_sad:
err... would take quite a few of flipflops, though...  :icon_lol:
dschwartz
ehm..please describe a flip flop?
3 mentions in the threads deserve a reference...
puretube
puretube
1 4013 contains 2 flipflops...
Quote from: puretube on June 03, 2008, 05:25:31 PM
OK - use a CD4024 seven stage ripple counter to divide by 2, 4, 8, 16, 32, 64 and 128!
