how hard are RATS to T/B ?
Started by sjaltenb, June 10, 2008, 06:46:42 PM
sjaltenb
Hey Yall.
I want to put a RAT in my COrnish board which uses 3PDTs for bypass. The boss pedals are easy cuase i just make them always on and use the input/output leads.
How hard would it be on the RAT... I know it uses some type of special bypass...I dont want to have to do a ton of mods to it. Using the in/out  leads are fine with me as long as I can make the pedal always on easily...
earthtonesaudio
The Rat is already true bypass.
sjaltenb
but doesnt it use a relay switch.
i need to know if its hard to convert to use with a 3PDT.
soulsonic
Just remove the footswitch and wire directly to the in/out leads of the board; it will be always on that way.
earthtonesaudio
From what I've read, it just uses a DPDT, and one of the unused terminals is used to turn the LED on or off.
Ben N
ubersam
Quote from: earthtonesaudio on June 11, 2008, 12:08:45 PM
I read somewhere on GeoFex that the Rat uses some form of the Millennium bypass. It is somewhere on this document: http://www.geofex.com/Article_Folders/Millenium/The%20Next%20Millenium.pdf
ayayay!
Yes, it's using what RG later called the Millenium, which he improved upon several times over now.
The thing to remember is TB does not constitute ONLY using a 3PDT.  You can use those, DPDTs in Millenium bypass, and relays.   ;)
The people who work for a living are now outnumbered by those who vote for a living.
