Adding an LED to a simple fuzz face circuit WITHOUT a 3DPT switch?
Started by radioheadftw, June 16, 2008, 11:32:55 PM
radioheadftw
Hey guys,
I finally got my Fuzz Face to work (I posted a question about it before) and it sounds sexy sweet.
Now I want to add a status LED, but I only have a DPDT switch. I can't make millenium bypass, because its a positive ground circuit, but is there another way?
Or do I just buy a 3PDT switch?
DougH
QuoteI can't make millenium bypass, because its a positive ground circuit,
You can if you use a p-channel JFET.
Branimir
Yes, there is a "how to" on geofex I think, I used a millenium for a positive ground FF...
http://www.geofex.com/article_folders/millenium/milckt.gif
You can use a regular mil bypass pcb and reverse diode placement with a P channel mosfet (or jfet).
Umor
Built: Fuzz Face, Small Stone, Trem Lune, Fet Muff, Big Muff (green), Fuxx Face, Son of Screamer, Rat, Rebote 2.5, Opamp Big Muff, EA Tremolo, Easyvibe, Axis Face Si
radioheadftw
Is a 2N5460 JFET any good?
And, so I should just flip the diodes/LED on this circuit?
  "If you can't tell when your FF is 'on'...there's something wrong with your FF.
  Old quote 'o mine...funny ?
  Actually that's not exactly true, especially when many LED indicators need to be monitored, all my effects have indicators now.
  3PDT's are nice and easy.
  Glad to hear the PS short got sorted out, and that caused the FF to begin work.
  Another option, as you probably well know: NPN FF, Neg Gnd.
