Will a charge pump generate heat, does it need air?
Started by skiraly017, July 15, 2008, 10:20:13 AM
skiraly017
I have a project that will be using a charge pump on a daughterboard. It will be secured to the enclosure but I was also thinking about enclosing in shrink tubing just be extra safe. I've read posts about charge pumps heating up but if they're built properly and everything is running as it should, could I shrink tube the daughterboard with no worries? Thanks.
John Lyons
It probably depends on the current draw but you could test it with a finger to see if it gets warm in circuit before you wrap it up.
Probably ok though...
john
Basic Audio Pedals
www.basicaudio.net/
Paul Perry (Frostwave)
I've never seen one damaged by heat, when you try to draw too much current the voltage usually just sags.
What kills them - in my experience - is exceeding the specified peak input voltage. :icon_redface:
