Thanks to P. Marossy, R.G. And Alex for protoboard ideas. (Your pictures ?)
Started by frank_p, July 17, 2008, 11:55:01 PM
frank_p
After seeing those simple additions to a plugboard (or breadboard) that P. Marossy, R.G. and Alex made:
Paul's versatile one (DIYguitarist)
and R.G.'s elegant one:
Alex's ecological one:
I toughed it was kinda stupid not to do so: debugging is always hard work and very frustrating when the failure comes from that connector that disconnected itself by pulling it by the guitar cord or ... or ... or ... ;
So here is my attempt at "cloning" this irresistible and simple idea :
P.S.: I must add a "Boss type" walwart plug and some holes for LEDs.
Do you guys use something like this (?),
or have ideas about adding: connectors, battery holders and etc...
Yours F.H.P.
ambulancevoice
frank_p
Quote from: ambulancevoice on July 18, 2008, 06:54:07 AM
im not sure if this qualifies but its a good idea
http://www.beavisaudio.com/bboard/index.htm
Damn !  I knew I forgot somebodys, protoboard that I sawn...
Sorry Beavis.
Thanks Alex
Paul Marossy
frank_p
Quote from: Paul Marossy on July 18, 2008, 05:34:07 PM
I need to use my prototyping board more.  :icon_redface:
Well it's normal in that case :
"Hi. My Name is Paul. I am a recovered stompboxaholic."
:D
  I should have I guess, somehow, I've always found a way around it.
nelson
Here is the one I currently use.
Made from one of the rapid boxes, it's real easy to insert in a signal chain.
My project site
Winner of Mar 2009 FX-X
Paul Marossy
Quote from: frank_p on July 18, 2008, 05:53:06 PM
:D
Hmm... good point!  :icon_mrgreen:
Here's mine:
The box with sockets, stompswitch etc makes prototyping lots easier.
The two small circuits are a floating earth vref and a LM317 variable voltage supply - I'm playing about with submini tubes at the moment. they want 6.3 volts for the heaters.
Berger
Quote from: nelson on July 19, 2008, 02:37:48 PM
where do you the pots on the right? I have been looking for some but have been unsure what they really are.
-Aaron
frank_p
Richard's one (blanik):
Maintenant, il y a du pain sur la planche.
Quote from: Berger on July 29, 2008, 02:54:34 PM
-Aaron
Just came across this thread.  Some of those very pots arrived in the mail this week from SmallBear.
http://www.smallbearelec.com/Detail.bok?no=693
JFX09
well I was given a digi cam (by the quality of pic, you can see why it was given... nice gesture nonetheless)
anyway, here's mine
and a closer view
and in situ
inspired by those who paved the way, i bow to you gentlemen
jf
Happiness is a effin' hot soldering iron
Quote from: JFX09 on August 25, 2008, 06:25:54 PM
jf
That's awesome - I'm sooooooooooooooo jealous!
frank_p
gutsofgold
nelson, such a good idea with those mini pots. I think thats the route I will do with mine!
ConanB
I'm currently redoing my board, I'll try and get pics when I've done it.
DougH
anyway, here's mine
I like the use of the terminal strip! Smart!
JFX09
The terminal strip idea was robbed from Dano, it sparked the same sentiment when I saw how he used it (the Volt meter too, but then, i'm a sucker for everything meter...)
Rick, you shouldn't be jealous, your builds are top notch mate. Do you see those THD boards in the foreground ?
Frank: Well, If i'm going to sweat over it, might as well be pretty
Merci MONTRÉAL  *raises hands and grins*  :icon_mrgreen:
now if I could only get the Rat that sits on it to work *sighs*
Paul Marossy
