PEPPER SHREDDER
Started by Renegadrian, July 23, 2008, 11:54:37 AM
danielzink
It's funny - we all seem to be travelling on similar paths !
I have been working my pepper over in my mind lately and I'm going to install a toggle swith to bypass the tonestack as needed.
Dan
danielzink
Quote from: danielzink on October 31, 2009, 09:58:07 AM
Dan
Okay - well that was a massive failure - all I did was completely cut signal - yes....aparrently the TS-a and TS-b need to be connected......duh......
I have three toggle switches at my disposal and I need to eliminate the tonestack at will:
On/Off - two contacts
On/On - three contacts
DPDT - six contacts....
needing guidance - I'm sure it's simple.
Thanks, Dan
DPDT - imagine you'll bypassing an effect.
danielzink
kurtlives
Lift the mid pots ground connection. SPST is all you need.
My DIY site:
www.pdfelectronics.com
danielzink
danielzink
danielzink
Quote from: kurtlives on October 31, 2009, 01:12:13 PM
ahhhhhh........I re-read your post.....I misinterpreted what you said !
I think I've got it now !
danielzink
Quote from: danielzink on October 31, 2009, 02:26:34 PM
Just to be clear - this is the tonestack I'm using:
danielzink
So - a simple on/off between the gnd connection from the pepper board to the tonestack ?
Thanks everyone !!
Dan
kurtlives
Yep
Break the Blue wire or the Black wire, which ever...
My DIY site:
danielzink
Quote from: kurtlives on October 31, 2009, 03:07:43 PM
Yep
Off to solder - Thanks !
danielzink
Quote from: danielzink on October 31, 2009, 03:12:42 PM
Yep
Worked great - thanks again - oddly though - with the tone stack bypassed - turning the "treble" knob will slightly (ever so slightly) reduce the overall volume.
Just need to make sure the treble knob is at 10 whenever the tone stack is bypassed - no problem though - love it !
Dan
That's because the SPST doesn't truely bypass the tonestack. To truely bypass it you need the DPDT arrangement.  ;)
kurtlives
Ya forgot to mention that Dan.
Rick no offense but this method is way easier and does virtually the same thing. Never seen amp that "fully" bypasses the tonestack.
Really the treble pot shouldn't affect the volume too much, provided it seems the ideal input impedance. When boost engaged it should ever so slightly affect the highs. Dan are you using a Marshall TS, those rely on cathode followers before them generally.
My DIY site:
