Does this Muff fuzz vero look right
Started by guilds100, August 02, 2008, 10:26:53 AM
guilds100
I need another set of eyes to make sure I have done this correctly.
ambulancevoice
volume is the other way around
pin 3 should be where pin 1 is and vice versa (pin 2 is right)
all output volume pots are always 3 (in) 2 (out) 1 (ground)
diodes are wrong, try moving them to the right (that means youll need to have 9 holes) so there is a space between c3 and the diodes (just down to that jumper to ground at E3)
then connecting them to ground (not the 9v)
then putting volume pin 3 between c3 and the diodes
guilds100
Quote from: ambulancevoice on August 02, 2008, 10:46:56 AM
Im using the schematic in the upper right corner. Is this schematic wrong?
ambulancevoice
im going by this
i know thats the one alot of people build these days
i havnt seen the one youve posted before
guilds100
#4
That makes more sense. I do believe the one I was using is flawed. I think this is right.
ambulancevoice
put the volume 3 between c3 and the diodes
the way you have it is as it if was like this
Renegadrian
Barcode80
#7
Quote from: ambulancevoice on August 02, 2008, 10:34:09 PM
this actually looks more correct for output clipping...
the way phillip's shows in the schem you posted means that the diodes do nothing because you have already tapped off the output before any signal ever meets them. this altered example you posted that i quoted is actually the correct orientation of the parts.
spudulike
Quotethe diodes do nothing because you have already tapped off the output before any signal ever meets them.
wtf ?
ambulancevoice
#9
Quote from: spudulike on August 03, 2008, 06:21:21 AM
wtf ?
+1
why would ELECTRO HARMONIX put them there if they did NOTHING
GREEN FUZ
It shouldn`t make any difference, in this case, whether lug 3 of the volume pot is situated before or after the diodes. Both are correct. Look at the way the diodes have been implemented in the original.
http://www.aronnelson.com/gallery/main.php/v/DRAGONFLY-LAYOUTS_0/album146/FUZZ/EH+MUFF+FUZZ+2.JPG.html
That should explain it better than I could ever hope to.
Dragonfly
Whether the pot comes "before" or "after" the clipping diodes makes no difference whatsoever. They're still shunting signal to ground.
Check the nodes and you'll see.... it's the same either way. :)
Barcode80
Quote from: Dragonfly on August 03, 2008, 11:00:28 AM
yeah i guess that makes sense. just didn't seem logical to put them that way, but now i see what you are saying.
ambulancevoice
Quote from: GREEN FUZ on August 03, 2008, 09:07:47 AM
ah yeah
i was just following the schematic anyway
