Valve Jr head+cabinet arrived! now some pedals...
Started by Steben, August 06, 2008, 02:15:32 PM
Steben
Quote from: mac on August 12, 2008, 05:45:44 PM
QuoteBTW, there is no standby switch.
How tough is this in practice for the tubes?
It takes about 15 - 20 sec(?) before the sound gets through.
It was suggested to set volume at min when turning it on and wait 3min until tunrnig volume up and begin playing.
I guess that only works for class (A)B, where the power dissipation relates to the signal amplitude. I guess the LC15 is AB pushpull ?
In Class A (single-ended) the power dissipation is constant, no advantage there.
liddokun
Quote from: remmelt on August 13, 2008, 04:11:18 AM
Quote from: liddokun on August 12, 2008, 05:46:57 PM
Are standby switches easy to add? Should I add one to mines?
I don't want to sound like an ass, but if you have to ask, you'd probably be better off taking it to a tech. Dangerous voltages, you know the drill.
That said, yes, it's pretty easy. A decent SPST switch that can take the B+ voltage and ampere that breaks the line that goes from the rectifier to the first tube. Presto: standby.
You can also get an ON-OFF-ON switch (DPDT) if you don't want to mess with the looks of your amp. One side is standby, the other is play. Center is off. See: http://www.rru.com/~meo/Guitar/Amps/Kalamazoo/Mods/standby.html
I bought a 5F1 Champ kit at tubeampdoctor, and Andreas (the Doctor, I suppose) was kind enough to supply me with the following information:
the 5F1 has no standby switch.
We supply the kit only as they are I regret.
BTW, I would not install a stand-by with 6V6 or EL84 amps in SE.
not needed on the quick-warm-up tubes like EL84 or 6V6.
If too long run in stand-By it rather destroys the cathode then it
helps.
So IMO it is not needed with this amp.
He seems like a knowledgeable guy so I took his advice and left off the standby.
Ah, thanks for the information.  Don't worry about sounding like an ass, I guess I just asked a newbie question.  I'm pretty much new to tube amps, so I guess it's a common question.  I haev a friend who does all my amp work for me.
To those about to rock, we salute you.
