One knob, 1509a enclosure project. Any ideas
Started by seibertdr, August 10, 2008, 10:54:50 PM
seibertdr
I bought a 1509a enclusre by mistake. I go the right box for the project I was working on so it is left over. What project can I fit into this box. I would like a single know and a stompswitch and an LED ( I love LEDs  :icon_biggrin:). Any suggestion would be appreciated.
Take care,
Don
Mesa RK II
Ibanez RG570
Ibanez AR-300
Schecter Hellraiser
Gretsch G5120
Guitar>Bad Horsie wah>FullDrive 2>Boss OD-2>EHX POG2>Ernie Ball Volume>Amp
M9 in loop
andrew_k
Renegadrian
Tillman, Bazz Fuss, Rocket Boost, LPB...Tiny circuits, so...
Steben
#3
Smokey amp? (or little gem...)
Or a Steby boost?
I know you only want one knob, but you can get reasonable sized circuits in them if you want to, I built Mark Hammer's Crank into one.
The enclosure is actually a 27969P but it's the same size as a 1590A. If I can find some small enough pots I'm going to try a Tube Screamer or a DS1 next.
seibertdr
I like knobs too. That looks like a great build. I would like to try something else besides a booster.
Mesa RK II
Ibanez RG570
Ibanez AR-300
Schecter Hellraiser
Gretsch G5120
M9 in loop
Dragonfly
#6
Ice-9
What about a tremolo effect, You could easily make a tremolo with a 1 transitor buffer stage with a fet on the input to ground controlled with a 555 timer to turn on/off the fet. The 555 timer is wired as an astable thus putting a triangular wave on the gate of the fet. very simple to make with 1 pot to control the frequency of the timer (speed of tremolo) . i will see if i can sort a shematic if this inerests you.
www.stanleyfx.co.uk
seibertdr
Quote from: slacker on August 11, 2008, 12:41:45 PM
Do you have the schematic and layout for the crank. I might give that a go.
Mesa RK II
Ibanez RG570
Ibanez AR-300
Schecter Hellraiser
Gretsch G5120
M9 in loop
The Tourist
I've built a Red Llama in one. Used Madbean's layout.
MikeH
ppatchmods
I did a strat-o-blaster in one a while back.  Tight fit, but worth it!
Also did a fuzz from fuzzboxworld that would fit nicely.
When your life is over, will any of this STUFF really matter?
Quote from: seibertdr on August 11, 2008, 11:46:09 PM
The schematic is here http://hammer.ampage.org/files/The_Crank.gif
I'll draw up the layout I did, probably won't be until next week though.
The Tourist
Quote from: MikeH on August 12, 2008, 10:30:49 AM
Quote from: The Tourist on August 11, 2008, 11:56:17 PM
Pics!
I could have made more room for the board by putting the dc jack under the output jack...but I already drilled the hole when I realized this.
seibertdr
What size pots did you use for this one?
Don
Mesa RK II
Ibanez RG570
Ibanez AR-300
Schecter Hellraiser
Gretsch G5120
M9 in loop
