parallel universe led mod
Started by 1878, August 13, 2008, 10:59:16 AM
Just ordered the pots & enclosure for my parallel universe build. I want to add the oscillate footswitch and LED indicator. What would be the easiest way to achieve this ?? I've got SPDT, DPDT and 3PDT footswitches.
Still learning  ;)
Thanks in advance.
AzzR
just replace the osc switch with the DPDT wired as such
Leave empty  ---0--- Leave empty
LM386 lug 7   ---0--- Ground LED
C7                ---0--- +ve LED (9v plus resitor for LED)
The three dashes corresspond to a lug on the DPDT.
This is for the new schem, if using the old schem or can't understand my diagram just use the bottom 4 lugs of the DPDT and ignore the top 2. Wire the left two lugs the same as the osc switch and the right two lugs as you would with an LED in a TB switch.
Hope that helped.
-Azza
A Broken Clock Is Right Twice A Day
ambulancevoice
AzzR
1878
Cheers !!
I'm using the old schem. Should have made that clear from the start really  ;)
ambulancevoice
1878
That's the one I'm using  :icon_biggrin:
I'm still quite new to all of this, and I'm at that horrible point where I 'sort of' know what to do, but still need clarification from those who do know. Still... All part of life's rich tapestry as they say.
Thanks again.
1878
Any chance you could re-post the diagram please ?? Computer went down recently and I've lost the copy I had.
Thanks again !!
