SP3T switches - is there such a thing? Or miniature Rotary?
Started by frequencycentral, August 24, 2008, 09:21:48 AM
I'm looking for a switch. I have rotary switches, but they are 22mm - they take up a lot of space when all the pots I'm using are 15mm. A three position toggle would do the job - ON/ON/ON, the ON/OFF/ON type wouldn't do the job. Is there such a thing? A UK supplier would be great
rackham
Have you looked at slide switches?
Yes, mini rotaries exist. They are quite expensive in most cases and may be hard to find.
Quote from: rackham on August 24, 2008, 09:49:09 AM
I've bought some of these before:
Thanks, I'll check them out.
Quote from: R.G. on August 24, 2008, 11:36:51 AM
I would prefer not to use slide switches, as drilling rectangular holes is such a pain - I guess I would at a push - but I can't even find these at my usual suppliers.
Mini rotaries would be perfect - I only need a couple, so cost isn't really an issue. Any ideas about suppliers?
Also - I'm sure I read somewhere about using ON/OFF/ON toggles in ON/ON/ON mode.................?
EDIT: The other option I have considered (in my madness) is to use a 4017 with a momentary switch combined with a 4066 to step through four possible options. Now that would look cool - especially with four LEDs - but it adds a whole lot of circuitry!
What do you need the switch to do, like you said you might be able to make it work with an On/Off/On.
I've never seen SP3T toggles only sliders, the DPDT On/On/On switches work in a different way which may or may not work for what you want.
RickL
NKK lists a switch in a catalogue I have from 2001 (probably still available) that looks like a dpdt centre-off that can be wired as a sp3t. If the lugs are numbered:
1 2 3
4 5 6
left connects 1-2 and 4-5, centre connects 1-2 and 5-6, right connects 2-3 and 5-6. Run a wire between 2 and 6, 5 becomes your common, 4 is P1, 1 is P2 and 3 is P3.
They also make a similar switch (that looks like a 4pdt centre-off) that can be wired as a dp3t switch. I found out about them when I was rummaging through the sale bin in my local electronic supply place a couple of years ago and have used both versions. They're listed in my catalogue as M2024 and M2044 respectively.
Update: I just checked NKK's online catalogue, the switches are still available. Any electronic supply place should be able to order them. Steve - Small Bear may want to look into stocking these.
skiraly017
Mouser shows a SP3T on/on/on toggle by NKK, part number 633-M2024BB1W01-RO. Here's the data sheet.
any
smallbear carries a 9mm alpha 1p6t mini rotary.
Just don't know if you can limit the amount of throws...
It's supposed to sound that way.
calpolyengineer
Quote from: skiraly017 on August 24, 2008, 09:38:07 PM
That datasheet shows that the SP3T is in fact an On-On-On DPDT with pin 2 and 5 connected just as Rick said. I'm glad I stumbled upon this thread cause I have plenty of those On-On-On switches and nothing to use them on...yet.
-Joe
