Speaker load box "power soak LITE"? (schematic)
Started by Steben, August 26, 2008, 08:04:21 AM
Steben
16 ohm circuit.
Load based on Aiken's schematic, yet with a 8 ohm as base resistor.
I made some calculations and all positions should be similar to a speaker load line.
This is for 5 positions (-0dB, -6dB, -12dB, -18dB, 0), yet a 6th is easy to add.
Dai H.
Steben
Pushtone
I did something similar with three attenuation settings on a rotary switch.
I'm assuming the switch in your schem is also a rotary.
The rotary switch I have is an open frame break-before-make type.
I'm not sure if there is another type.
Anyway, my question is....
Is it safe to use this type of switch with a tube amp?
To be on the safe side I have been turning off the amp before changing atten levels.
I was going to include a bypass DPDT switch but I though that even more risky than the rotary.
So what about mechanical switches on an amplifier output?
Dave S
Steben
Quote from: Pushtone on August 27, 2008, 10:38:42 AM
Dave S
I suppose you refer to the pause when switching, where the amp "sees" no load?
I think that is quite exagerated, we are talking milliseconds here and unless you intend to switch more than you play the guitar, the wear will be smaller than the heater. I think the amp can do the switch more harm than otherwise, if you choose a "wimpy" one.
